Author Topic: "Ultra Diesel"  (Read 6373 times)
April 19, 2007, 10:50:18 am
Op-Ivy
  • 513
"Ultra Diesel"
« on: April 19, 2007, 10:50:18 am »
Well my car is out of order for a little while untill I get my fuel pump rebuilt. It started leaking so bad that when it was cold starting there would be a small pool of diesel on the ground... The diesel has been leaking onto a coolant hose as well and eventually it weakened burst open (fortunately when it was idling in the driveway). Also, my transmission is still leaking due worn inner bearings.
Anyways on to my question. I was at shell filling up my girlfriend's car when I saw that they had "Ultra Diesel". After a bit of research I recieved this response.
Matt,
Ultra Diesel is our premium grade of diesel. The difference is that Ultra Diesel
has a higher dosage of detergent additives, and also it contains de-icers,
corrosion inhibitors and demulsifiers. regular use of Ultra diesel will help to
keep the fuel intake system free of deposits thus maintaining the engine
efficiency.
Attached is a bulletin on Shell Ultra Diesel for your reference.
Thanks
Mahinda Ranaweera
Technical Representative lubes & Fuels
Shell Canada Limited
And what was attatched...
Does this sound legitimate? Is it worth the 3 cents per litre? I have my doubts.
-Matt
Reply #1April 19, 2007, 01:36:51 pm
Black Smokin' Diesel
  • 656
"Ultra Diesel"
« Reply #1 on: April 19, 2007, 01:36:51 pm »
Dunno if it will actually increase performance but it seems legit. Is the price the same? Probably not...
Reply #2April 19, 2007, 02:28:35 pm
foxracer1
  • 991
"Ultra Diesel"
« Reply #2 on: April 19, 2007, 02:28:35 pm »
The truck in the picture is a dakota! They don't run ultra diesel.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #3April 19, 2007, 04:35:42 pm
westcoaster
"Ultra Diesel"
« Reply #3 on: April 19, 2007, 04:35:42 pm »
Or it's a spin on the ultra low sulpher diesel all refineries have been mandated to produce starting jan 1 '07
This is to coinside with the new EPA regulations regarding diesel vehicle emmisions for Jan 1 '07 The next big crunch comes in 2010 (or was that 2011?)
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #4April 19, 2007, 09:08:58 pm
OM617
"Ultra Diesel"
« Reply #4 on: April 19, 2007, 09:08:58 pm »
Diesel is Diesel. All the stations buy their fuel from the same few refineries. The only difference is the additives they put in it.
Reply #5April 19, 2007, 09:33:26 pm
"Ultra Diesel"
« Reply #5 on: April 19, 2007, 09:33:26 pm »
I ran a tank of Shell ultra diesel. Nothing fancy, no noticable power gains or increased MPG. I know that one tank is hardly enough to form an opinion on though. It's only $1.50 more per tank
Reply #6April 19, 2007, 09:58:09 pm
Dr. Diesel
  • 1341
"Ultra Diesel"
« Reply #6 on: April 19, 2007, 09:58:09 pm »
they don't mention anything about increased Cetane rating. I think Sunoco gold diesel has higher Cetane though.
Reply #7April 20, 2007, 04:40:27 am
Jetta Fan
  • 286
"Ultra Diesel"
« Reply #7 on: April 20, 2007, 04:40:27 am »
You guys can get more than one grade of diesel??  :?
Around here, all I have seen is just plain old diesel.
I add Power Service with each fill up for added lubricity, cleaning and a cetane boost.
1997 Jetta 1.9TD AAZ
Reply #8April 21, 2007, 05:58:51 am
Kudagra
  • 738
    • www.no-coast.com
"Ultra Diesel"
« Reply #8 on: April 21, 2007, 05:58:51 am »
Quote from: "foxracer1"
Ahhh but it would be nice to get a Dakota with a 4BT Cummins wouldnt it???
Just imagine what a tire roaster it would be with a worked 6BT out of its bigger brother.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #9April 21, 2007, 11:28:48 am
foxracer1
  • 991
"Ultra Diesel"
« Reply #9 on: April 21, 2007, 11:28:48 am »
Quote from: Kudagra
Quote from: foxracer1
Yes i agree ^
91 S10 305 TPI T56
Reply #10April 21, 2007, 02:45:17 pm
lesharoturbo
  • 78
"Ultra Diesel"
« Reply #10 on: April 21, 2007, 02:45:17 pm »
Around here (Mid Michigan) you see "Premium" diesel.  From what I understand, it is #1 diesel whereas regular diesel is #2.  There is a slight cetane increase for #1 compared to #2.  Most gas stations only carry #2.
Bernie
Reply #11April 24, 2007, 01:50:50 am
jannemann
  • 10
"Ultra Diesel"
« Reply #11 on: April 24, 2007, 01:50:50 am »
hi, here in Germany some gas stations have something like that too. Called V-Power (Shell) for instance.
After my opinion it really increases something...but not the engine power nor the top speed or something like that but only the income of Shell & co and it brings tax to the state`s pocket.
For compare:
Normal Diesel: ~1,10 € /l
V-Power       :~ 1,20 €/l
So I decided to drive with used vegoil, cleaned to 1µm for 0,49€/l but that`s another topic..
Jan
sorry for my  english  :o)
Reply #12April 25, 2007, 07:19:15 pm
ricosuave
  • 244
"Ultra Diesel"
« Reply #12 on: April 25, 2007, 07:19:15 pm »
i found my 97 aaz wouldnt give as many kms/tank with the ultra diesel compared to the regular shell diesel.  tried a few different times at different season - always worse
i havent tried it in my tdi though
