General Information
FAQ/Tech Tips/Please Read First
1.6 IDI Timing Advance Mod.
4
Topic: 1.6 IDI Timing Advance Mod. (Read 64898 times)
April 18, 2007, 10:17:54 pm
DVST8R
April 18, 2007, 10:17:54 pm »
Now let me preface this by saying that this is not my work, it was lifted off the voertex and was posted by:
TurboDieselTech
So give the credit there. Here is a link to the post
http://forums.vwvortex.com/zerothread?id=3190912
but this is what it says incase the link goes bad:
Quicker acceleration and better mileage... Change the injection timing advance curve...
This CAN be done on the car without removing the injection pump. On the side of the pump facing the front of the car, there's a round plate with two screws. This is where the advance mechanism lives. Before you begin, go to the dealer and get the seal kit for the advance piston housing. It'll consist of two large green o-rings, several smaller ones and an e-clip. Cost is about $5.
Loosen the cover, using a T30 Torx bit. Now you are going to remove the screws and cover. Be careful as there is a rather large spring behind the cover, as well as some spacer shims. Once the cover is off, you should find two shims between the spring and cover, and if you remove the spring, there will be one more shim. Take all of them out and look at them. Take the thickest one and set it aside... you won't be needing it. Now, smear some vaseline on both ends of the spring and stick a thin shim to each end. Insert the spring back in and put the cover back on, using a new o-ring. You must have a shim on each side of the spring, otherwise the spring will "machine" the aluminum cover and advance piston, filling your pump with fine metal filings... thus destroying the pump and injectors. Take a ride and feel the throttle response!
For those of you that have access to parts for these pumps (new or used), you can get even better throttle response and power by changing the advance spring too... Just replace the spring currently in your pump with a "lime green" colored spring. This spring has the softest spring rate and allows the pump to advance the timing MUCH sooner, with more overall advance. These springs are commonly found in early rabbits (pre 80) and Vanagon diesel pumps. Color codes from softest spring rate to hardest is as follows... Green, Red, yellow, silver, and blue. The hardest spring rates will give the LEAST timing advance.
The Brett of the board...
The Dark Side of Beauty.
[/i]
April 19, 2007, 07:35:53 am
Moderator
April 19, 2007, 07:35:53 am »
Kick ass!
http://www.tunezilla.com
93 Eurovan AHU TDI
97 Golf Variant Syncro 1.9L 1Z TDI -
sold and missed
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
April 19, 2007, 02:24:03 pm
foxracer1
Authorized Vendor
April 19, 2007, 02:24:03 pm »
I'm in the market for a green spring if any one has one!
haha
Thats some good info nice work.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
April 19, 2007, 02:48:21 pm
foxracer1
Authorized Vendor
April 19, 2007, 02:48:21 pm »
I just looked at the pump i have apart and it GREEN! So now i must go tear the one on the car apart.
Did we ever figure out if machineing the cover out would benefit any? I believe fspgtd had a thread about it a while back.
91 S10 305 TPI T56
April 19, 2007, 04:52:46 pm
MaxHedrm
April 19, 2007, 04:52:46 pm »
If removing a shim does, I would assume that machining the cover would have the same effect.
DRIVE:
2010 Golf TDI
DRIVE (less):
2001 TT Roadster
April 19, 2007, 06:57:18 pm
foxracer1
Authorized Vendor
April 19, 2007, 06:57:18 pm »
fspgtd was talking about machining the cover where the piston would bottom out. Not where the spring rides. He was trying to achieve more overall advance not earlier advance.
But i will try this green spring removew a shim mod this weekend
91 S10 305 TPI T56
April 20, 2007, 01:19:01 am
nkb
April 20, 2007, 01:19:01 am »
this work with 1.9s too right? i mean it should??? im a lucky guy with a blue spring
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
April 20, 2007, 06:09:53 am
AdAm84
April 20, 2007, 06:09:53 am »
Nice! I think i might try this one. Sounds a little more simple than the governer mod.
April 29, 2007, 12:11:53 pm
Laurentian
April 29, 2007, 12:11:53 pm »
So if I understood correctly this is for a 1.6D and not 1.6TD?
I just looked at my 1.6D pump and it does have the cover
with the two torx screws.
Let me know!
Thanks!!
Hugh
April 29, 2007, 01:09:48 pm
DVST8R
April 29, 2007, 01:09:48 pm »
Quote from: "Laurentian"
1.5D, 1.6D, 1.6TD, 1.7D, 1.7TD, 1.9D, 1.9TD, 2.4D, 2.4TD, and probably even the early cummins VE pumps. :wink:
[/i]
April 29, 2007, 01:53:33 pm
Benjamin
April 29, 2007, 01:53:33 pm »
i think this only can be done good with the right IP internal pressure!
though i cant say much about it becouse my knowledge and english is not good enough for it.
anyway, i think its not so simple to have the best timing set up without a dyno and monitoring
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
Reply #11
April 29, 2007, 02:13:21 pm
Reply #11 on:
April 29, 2007, 02:13:21 pm »
does anyone have a source for these green springs?
Reply #12
April 29, 2007, 05:52:58 pm
Reply #12 on:
April 29, 2007, 05:52:58 pm »
Of course, if you do those mods, do you still want to change the initial advance, or will that advance your timing too much, and how do you know?
Reply #13
May 12, 2007, 03:18:29 pm
84Q
Reply #13 on:
May 12, 2007, 03:18:29 pm »
i just went out and did the mod (on my '84 quantum), and the car is now slower. so....? it has the silver spring, but shouldn't removing the largest washer still have had a positive effect? nothing ever seems to go smoothly with this car...but i love it nonetheless.
Reply #14
May 14, 2007, 05:33:12 am
saurkraut
Reply #14 on:
May 14, 2007, 05:33:12 am »
There seems to be a general consensus that more advance is always good. When I temporarly used non-TD injectors (which essentially gave me more advance) in my 1.6TD, I noticed a decrease in top end power too.
So by doing this spring mod, you might be putting yourself out in the long grass and actually decrease your HP.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
4
General Information
