Author Topic: intermittent acceleration problems- TD 82 caddy  (Read 3938 times)
April 16, 2007, 03:31:05 pm
floyders
  • 9
« on: April 16, 2007, 03:31:05 pm »
For some reason my caddy just looses acceleration every once in a while.
It usually happens when I am starting from a stop or try to accelerate quickly- but not always. Just really random.
anyhow. I just had my injector pump replaced and it is still happening. It was only happening for about 3 days before i replaced the pump.
I will be pressing the gas pedal when all of a sudden , i can't accelerate even if I push it to the floor. Given a couple of seconds it usually kicks back in.
any ideas??????
Thank you all
Reply #1April 17, 2007, 04:45:49 am
Doug
« Reply #1 on: April 17, 2007, 04:45:49 am »
Did you do the easy stuff like check the fuel system for restriction such as a blocked filter or water separator or fuel tank pickup screen? Look for air bubbles in the clear fuel line supplying the fuel pump.
Reply #2April 17, 2007, 09:16:03 am
« Reply #2 on: April 17, 2007, 09:16:03 am »
Quick accleration requires alot of fuel, I'd look into what Doug suggested
