General Information
General
Need a little help guys....
Topic: Need a little help guys.... (Read 3821 times)
April 15, 2007, 03:08:59 pm
Trouser Trout
Newbie
April 15, 2007, 03:08:59 pm »
A co-worker has a TDI engine out of a 95 Jetta that does not run. It sounds to me as though it spit the belt off and bent a couple of valves, although this has not been confirmed. The engine obviously does not run, and does not include anything except the engine itself. Can anybody give me a ballpark price on the thing, it's the last piece of the puzzle that I need to finish my 90 Golf. Thanks for any help.
April 15, 2007, 03:38:03 pm
Turbinepowered
April 15, 2007, 03:38:03 pm »
If it were
I
buying it, I'd say no more than ~$600 or so. If it spit a belt and trashed the valves, you have quite a bit of work ahead of you, and that could get quite costly.
April 15, 2007, 04:02:46 pm
Patrick
April 15, 2007, 04:02:46 pm »
If the engine is original to the '95 it's probably a 1.9 idi, not tdi. A lot easier to put in your '90, still mechanical injection. Will be costly to repair though......
April 15, 2007, 04:33:07 pm
April 15, 2007, 04:33:07 pm »
Does it include the pump, turbo, manifolds, line etc etc?
If it is the AAZ I wouldn't pay more then $400 if the timing belt had jumped even if it had all the accessories.
If it is the AAZ then there is the whole crank pulley issue which will need to be dealt with, and this could actually be what caused the problem.
April 15, 2007, 05:48:18 pm
Trouser Trout
Newbie
April 15, 2007, 05:48:18 pm »
Thanks for the help so far, guys. It does include a very recently rebuilt turbo, as well as the injector pump. From what I understand, it is a mechanical pump, the car could be a 96, my memory does NOT serve me well.
General Information
General
