Author Topic: Snapped main bearing bolts  (Read 4110 times)
April 15, 2007, 12:21:48 pm
andysimpson
« on: April 15, 2007, 12:21:48 pm »
My AAZ has broken 2 of its main bearing bolts resulting in a totallt dead engine. Its an early AAZ with the short bolts, i have a replacement engine with the long bolts, i assumed the long bolts were because the main bearing caps had been modified which they have not. I know of another AAZ which has done a similar thing are there any others out there?
Does anyone know of an uprated bolt or cause?
The other one was standard as far as i know, mine is very modified in a vanagon syncro so working hard.
I just don't want a repeat of this.
Reply #1April 15, 2007, 12:45:45 pm
Wingaman
  • 7363
    • http://www.dmfdiesel.com
« Reply #1 on: April 15, 2007, 12:45:45 pm »
It's the first time I heard this  :shock:
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #2April 15, 2007, 12:58:40 pm
Audi80
« Reply #2 on: April 15, 2007, 12:58:40 pm »
Does this look familiar?
Kilck
Reply #3April 15, 2007, 01:00:37 pm
Wingaman
  • 7363
« Reply #3 on: April 15, 2007, 01:00:37 pm »
Holy***  :shock:
Reply #4April 15, 2007, 01:07:50 pm
andysimpson
« Reply #4 on: April 15, 2007, 01:07:50 pm »
Quote from: Audi80
Kilck
Yes just like that and then broken bits had a fight with a piston and con rod. Do you know what year engine was or the number the bolts chnaged at 560001 early 94. Mine had a different bolt, your has a shoulder mine was fully threaded. Engine standard or modified?
How many more?????
Have looked at the ARP catalogue but can only find early main bolts listed (65mm ones) i need the 80mm ones.
Reply #5April 15, 2007, 01:23:24 pm
Audi80
« Reply #5 on: April 15, 2007, 01:23:24 pm »
It was 5 cylider 2,4D with 80mm bolts (5 cylinder aaz) It was a little modified,  but not much ~140whp. No more cracked caps: pic  :wink: Used 12.9 allen head bolts.
Reply #6April 15, 2007, 01:41:22 pm
andysimpson
« Reply #6 on: April 15, 2007, 01:41:22 pm »
Quote from: Audi80
Just looked up the part number for the 5 pot bolts its the same as the late AAZ's. I have been thinking about 12.9 bolts, there 10.9 standard. I have also thought about braces under the caps, will have a look tommorow if there is room.
Reply #7April 16, 2007, 03:21:11 pm
935racer
« Reply #7 on: April 16, 2007, 03:21:11 pm »
Good grief what are you guys doing to these things? :shock:  I've never had any main cap or bolts failure issues one these things.
Now crank sprocket/nose failure and the mains being round after such a failure is another story...
Reply #8April 16, 2007, 10:56:14 pm
Audi80
« Reply #8 on: April 16, 2007, 10:56:14 pm »
I´ve heard of many cases, it´s not that rare :? Can´t say what causes it, but that 2,4 did have broken piston (between rings) and that cracked main cap. Luckily nothing else did broke.
When I started to build my 1,6, the reinforcement bar was the first thing my machinist told me to do :roll:
