Author Topic: My new toy. (G rated)  (Read 6614 times)
April 05, 2007, 08:59:26 pm
Dr. Diesel
  • 1341
« on: April 05, 2007, 08:59:26 pm »
just picked this badboy up:
clip the probe onto #1 (or whichever) injector line, hook it up, attach inductive timing light to the loop on the board, and voila! You can time your diesel engine like a gasser, by degrees, instead of mm. Also features a digital tach reading, and a bunch of cool other things.
byebye dial indicator.
(off you go to the back of the tool drawer )
 :D
Reply #1April 06, 2007, 05:42:29 am
« Reply #1 on: April 06, 2007, 05:42:29 am »
Where'd you find that neat toy?
I really need something like that. I'm almost positive that my actual timing is off even though my dial indicator says its spot on
Reply #2April 06, 2007, 06:58:21 am
Dr. Diesel
  • 1341
« Reply #2 on: April 06, 2007, 06:58:21 am »
two words. E and Bay
Reply #3April 06, 2007, 07:19:26 am
« Reply #3 on: April 06, 2007, 07:19:26 am »
Quote from: "Dr. Diesel"
how much would you charge to do timing??? i wouldn't mind getting mine bang on!
btw, i wonder if it would be possible to use the TDI sensor's to make a timing system... like the wire for the 3rd injector, and the crank sensor?
Reply #4April 06, 2007, 10:14:48 am
subsonic
  • 1836
« Reply #4 on: April 06, 2007, 10:14:48 am »
Would that system help with people who have swapped a TD engine into a different make vehicle and used the ACME adapter plate to use the non vw transmission?  I though I read somewhere that was aproblem?
Reply #5April 06, 2007, 10:39:13 am
« Reply #5 on: April 06, 2007, 10:39:13 am »
Quote from: "subsonic"
theoretically if you find TDC on the crank, you can time the engine properly.  with dr. diesel's new toy *drool* he can time the engine to within new spec because that machine will allow you to time the engine by actual injection.  old tired pumps have a delay in the injection, so mechanically timing it by the book doesn't cut it.
very precise!  so how much $$$ :)
Reply #6April 06, 2007, 11:17:40 am
SMOKEYDUB
  • 630
« Reply #6 on: April 06, 2007, 11:17:40 am »
I can finally dial in my giles pump and squeeze every little hp out of it i can.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #7April 06, 2007, 04:46:21 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #7 on: April 06, 2007, 04:46:21 pm »
We are suppost to have something like that at work. Maybe I can get them to buy one.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #8April 07, 2007, 05:25:08 am
Dr. Diesel
  • 1341
« Reply #8 on: April 07, 2007, 05:25:08 am »
yeah...... the only issue being that there is no information as to what degrees equals what mm. I'll need to make up a specs list using an engine with a new camplate in it's pump. Smokeydub, it looks like you just saved yourself A MILLION DOLLARS!! HAHAHAHAHAHAAAAA!
We'll use your new Giles pump to figure out those specs, then I can charge eveyone else A MILLION DOLLARS!! HAHAHAHAHAHAHAAAA!! to check their timing.
As said above, if you can find a definite TDC mark, you should be able to time the pump by either method.
Reply #9April 07, 2007, 06:01:48 am
« Reply #9 on: April 07, 2007, 06:01:48 am »
one million dollars (austin powers style) hehehe
Reply #10April 07, 2007, 10:11:42 pm
  • 2931
timing light
« Reply #10 on: April 07, 2007, 10:11:42 pm »
I was playing around with a few flywheels and it looks like 50mm=24degrees.
 That was measured on the flat area running around the flywheel, above the timing mark.
Reply #11April 08, 2007, 05:56:47 am
Dr. Diesel
  • 1341
« Reply #11 on: April 08, 2007, 05:56:47 am »
oh. i meant degrees crank vs mm dial indicator-in-pump.
Reply #12April 09, 2007, 07:08:37 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #12 on: April 09, 2007, 07:08:37 am »
The only thing better then buying one of those Tach-n-Times your self is telling your boss about it and the company orders it. Now I have one to use and I didnt have to spend a dime.
Sweet Doc...that info would be great....and I promise to give you a useage fee if I make money with it...:D
Reply #13April 09, 2007, 08:27:46 am
Dr. Diesel
  • 1341
« Reply #13 on: April 09, 2007, 08:27:46 am »
for you, half A MILLION DOLLARS!! HAHAHAHAHAHAAAAA!  :D
Reply #14April 24, 2007, 08:26:27 pm
Mk2Fanatic
  • 93
« Reply #14 on: April 24, 2007, 08:26:27 pm »
Another one on ebay...Item#290108941611
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
