Author Topic: Princess Auto RULES! Check out this cool item!  (Read 11586 times)
April 03, 2007, 06:52:19 pm
« on: April 03, 2007, 06:52:19 pm »
Get yours today!
would be great for hauling around transmissions.. motors.. parts..  8)
Reply #1April 03, 2007, 07:32:43 pm
QuickTD
  • 1156
« Reply #1 on: April 03, 2007, 07:32:43 pm »
That thing fits a class 3 hitch. 2" (class 3) hitches are pretty much limited to trucks that have sufficient frame strength to bear 500lbs of tongue weight. I don't believe you'd want to adapt this device for use on a typical class 1 hitch on a VW or you'll be buying a princess auto mig welder to rebuild the trunk floor...
Reply #2April 03, 2007, 08:21:58 pm
« Reply #2 on: April 03, 2007, 08:21:58 pm »
Quote from: "QuickTD"
hmmmmmmm or i could just beef it up a bit??? i've towed over 1000 lbs in my '86 jetta... that thing was a pig!
Reply #3April 03, 2007, 09:01:59 pm
QuickTD
  • 1156
« Reply #3 on: April 03, 2007, 09:01:59 pm »
I've towed over 1000lbs with mine as well, but hanging 500lbs directly off the reciever is quite a lot different than towing it.
 Most hitches for VW's bolt through the unibody sheet metal and won't really support much more than the rated 200lbs of tongue weight, not to mention 500lbs hanging off the back like that would likely lighten the front wheels quite a bit. Might make for good burnouts but not so good for safe driving. Engines and trannys fit in the trunk, so thats where I'd put them...
Reply #4April 04, 2007, 08:58:29 am
« Reply #4 on: April 04, 2007, 08:58:29 am »
you've fit an engine in the trunk??? hmm... did you have to keep it open?
on another note, i went to pick up the TDI and saw that the lower bracket for the power steering pump is all bent...  :evil: hopefully i can straighten it up!  looks like the oil pump got dinged good too... wonder if i should trust the cheapie oil cooler???
Reply #5April 04, 2007, 09:08:25 am
QuickTD
  • 1156
« Reply #5 on: April 04, 2007, 09:08:25 am »
Nope, temporarily relocate the spare tire and let the oil pan sit in the spare tire well. Granted, mine is a Mk3 so the trunk is huge, but I suspect that you could fit a motor in as well, just lean it over a bit. Engines will easily fit in lying on their side but then the "juice" tends to come out...
Reply #6April 04, 2007, 09:40:13 am
« Reply #6 on: April 04, 2007, 09:40:13 am »
hehe juice!  I'll have to try that sometime... I've never really tried to fit a motor, just a tranny, and that seemed to work fine.  (tranny's are pretty light, considering my weak self can lift one)
Reply #7April 04, 2007, 09:59:00 am
dieselsnowmobile
  • 103
« Reply #7 on: April 04, 2007, 09:59:00 am »
This is what happens to a Jetta if you try to put 500 lbs of wood on it.  Just imagine putting 500 lbs behind the bumper on your "Cargo Hauler."
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #8April 04, 2007, 10:14:14 am
« Reply #8 on: April 04, 2007, 10:14:14 am »
I'd had a complete 1.6 NA, a tranny, enough tool to do an engine swap, a full sized tire, the spare tire, and a bunch of other random parts in the trunk of my mk2, plus I had an engine hoist (the one from c-tire) and 2 rabbit bumpers in the back seat, oh and a toolbox on the pssanger seat.
My mileage was kind of crappy but I made it all the way to Brampton no problems.
Reply #9April 04, 2007, 03:13:52 pm
« Reply #9 on: April 04, 2007, 03:13:52 pm »
Quote from: dieselsnowmobile
That's a hell of allot more than 500lbs!
Reply #10April 04, 2007, 03:26:57 pm
« Reply #10 on: April 04, 2007, 03:26:57 pm »
not to mention a p-shop :lol:
Reply #11April 04, 2007, 03:29:19 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #11 on: April 04, 2007, 03:29:19 pm »
Quote from: "burn_your_money"
Thats not a photoshop.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #12April 04, 2007, 03:34:24 pm
« Reply #12 on: April 04, 2007, 03:34:24 pm »
the rear wheel is at least 3" smaller...
Reply #13April 04, 2007, 03:35:11 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #13 on: April 04, 2007, 03:35:11 pm »
http://www.snopes.com/photos/automobiles/lumber.asp
That is a blown tire.
Reply #14April 04, 2007, 04:07:39 pm
« Reply #14 on: April 04, 2007, 04:07:39 pm »
very strange indeed... the rim is still smaller in the back then the front though
