Author Topic: 1.6TD into a 1.9TD, what glow plugs?  (Read 4492 times)
April 02, 2007, 09:18:07 pm
« on: April 02, 2007, 09:18:07 pm »
I'm in the process of putting a 1.6TD into a 95 golf in place of a 1.9TD. What do I need to do to be able to use the 1.6TD glowplugs or are they a direct swap?
Reply #1April 03, 2007, 07:19:58 pm
andy2
« Reply #1 on: April 03, 2007, 07:19:58 pm »
The eaiest solution would be to use the 1.9 glow plugs in the 1.6.The duraterm ??? bosch glow plugs are commonly used in the 1.6 anyways.
Reply #2April 03, 2007, 08:27:26 pm
« Reply #2 on: April 03, 2007, 08:27:26 pm »
and the glow plugs stay on for a few minutes after starting to keep it running okay... the duraterms should hold up nicely!
Reply #3April 04, 2007, 01:29:02 pm
« Reply #3 on: April 04, 2007, 01:29:02 pm »
Thanks guys, I had heard bad things about the plugs staying on too long and whatnot so I didn't want to use to the 1.9 gowplugs.
Reply #4April 04, 2007, 02:21:26 pm
andy2
« Reply #4 on: April 04, 2007, 02:21:26 pm »
Its not the 1.9 glow plugs that are the issue I've only saw 1 gp relay stick on,thats one too many though.
Reply #5April 04, 2007, 02:34:12 pm
« Reply #5 on: April 04, 2007, 02:34:12 pm »
Quote from: "andy2"
Right, and Iw as kind of hoping it would be as easy as swapping relays. I have Bosch duraterms, hopefully everythign works
