Author Topic: Total Seal Rings  (Read 3950 times)
December 08, 2004, 07:12:37 pm
Rat407
  • 289
Total Seal Rings
« on: December 08, 2004, 07:12:37 pm »
Has anyone used Total Seal rings in there 1.6 TD?  I'm looking at putting them in my engine and just wanted some true to life story on them.
Thanks
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #1December 09, 2004, 03:43:11 am
Dr. Diesel
  • 1341
Total Seal Rings
« Reply #1 on: December 09, 2004, 03:43:11 am »
i priced them out. they were a little over $350 cdn +tax.
Reply #2December 09, 2004, 08:57:33 am
Peter
  • 136
Total Seal Rings
« Reply #2 on: December 09, 2004, 08:57:33 am »
I have installed rings by Hastings...a more modern design of the compression ring...being thinner then stock and able to push against the cylinder wall tighter...the oil control rings really work good also in cutting down the oil consumption...so well that I drove from Detroit to Key west and back again on 1/2 a quart of oil..and these rings were installed into a tired motor...once again  new life
Reply #3December 09, 2004, 02:39:23 pm
2mn2
Total Seal Rings
« Reply #3 on: December 09, 2004, 02:39:23 pm »
Quote from: "Peter"
What sort of cylinder prep (type of honing) did you do on this engine?
Reply #4December 10, 2004, 07:34:35 am
Peter
  • 136
Total Seal Rings
« Reply #4 on: December 10, 2004, 07:34:35 am »
the cyls were still narrow enough that when useing the new rings, the ring gap was back to within the lower end of "gap specs"...I simpily used a fine quality sand paper to scuff up the walls...60,000 later, and I am still doing fine...I am now useing a little oil between changes....
Quote from: "2mn2"
Quote from: "Peter"
