Author Topic: Nuts and bolts etc..  (Read 4141 times)
April 01, 2007, 06:06:19 am
subsonic
  • 1836
« on: April 01, 2007, 06:06:19 am »
Just got my first TD engine on the stand last night and tore it down to the block.  Which nuts and bolts do you reuse, and which do you replace with new?  I am talking valve cover all the way down to the oil pan?  What other components do you reuse?  I am thinking about replacing the water pump, alternator, and starter( going with early style).  all other brackets and such will be cleaned blasted and repainted.
Reply #1April 01, 2007, 07:35:05 am
subsonic
  • 1836
« Reply #1 on: April 01, 2007, 07:35:05 am »
I forgot to mention, I will be going with the ARP head studs, Main bolts, and crank bolts. So, other than that, what bolts do you go new with.
Reply #2April 01, 2007, 12:43:10 pm
« Reply #2 on: April 01, 2007, 12:43:10 pm »
well you're pretty much replacing the stretch bolts... all i know of are the head bolts, rod bolts and main bolts...
so it seems that you are good to go!
