Author Topic: Why is my GTD running so well?  (Read 7281 times)
Reply #15April 02, 2007, 01:13:21 pm
MontanaGTD
  • 230
    • http://www.dub-style.com
« Reply #15 on: April 02, 2007, 01:13:21 pm »
Nope - havent changed tyres size!
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #16April 02, 2007, 03:36:03 pm
SMOKEYDUB
  • 630
« Reply #16 on: April 02, 2007, 03:36:03 pm »
I know on a newer late model car when a 100 amp alternator is working and giving all its got it takes away 2 hp. On an older 100 amp alternator i would on suspect 4 hp. Instead of wiring up a bunch of crap why not turn up fuel and boost a little bit?
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #17April 03, 2007, 01:41:28 pm
Black Smokin' Diesel
  • 656
« Reply #17 on: April 03, 2007, 01:41:28 pm »
Quote from: libbybapa
My point with the cooling fan is that there is not any reason to cut power to it.  It is sensor controlled and so only ever comes on if you actually need it to.  Disabling it at that time would be very unwise.  Likely a WOT (hey, where's the throttle?) would never see the cooling fan come on, but then again if it should, not letting it would not be worth the brief hp improvement...
Andrew
If the alternator is killed at WOT the cooling fan will run off the battery so it won't rub power from the engine anyway.
