Author Topic: FS: Lots of 1.6L TD Parts - Pump, Block, - NEW PRICES!!!!!  (Read 9494 times)
March 29, 2007, 12:06:23 pm
NOTORIOUS VR
  • 83
« on: March 29, 2007, 12:06:23 pm »
Alright... selling for a friend some 1.6L TD parts.
- Modified Diesel Pump (w/ LDA)  Govenor and fueling mods done - SOLD
- 1.6L Cams - $50
- Block w/ crank, pistons, conrods, oil/vacuum pump, etc...  all in great shape, approx 250k - $170
NEW ITEM RACEWARE HEADSTUDS (used) - $160
- Intake Manifold w/ disabled BOV (holds 28 psi no problem) - $50
- 1.6L Head, in good shape, but has a crack on the outside of one of the injector bungs, can be welded no problem, and motor still runs with this head on it.  Can also be repaired for you by request - $170
-TD Cluster w/ 16V speedo (260km/h), and tach!  One wire connector, everything works, and is in perfect condition!  - SOLD
-TD Cluster w/o tach, everything works, one wire connector.  - SOLD
-4S Tranny, mint, no grinds.  - $160
-Alternator Bosch remanufactured (used) - $45
Also have 1.9L TDI parts:
Exhaust Manifold with K03-005 turbo - $160
All parts are located in Brampton, ON  Canada
Prices are in CND funds and are OBO, but no low balls please.
Buyer pays shipping
Cash and Paypal accepted
Contact Info:
Email:  notorious _ vr [at] gmail (dot) com
PM is ok too.
Reply #1March 29, 2007, 12:45:50 pm
« Reply #1 on: March 29, 2007, 12:45:50 pm »
Was the pump rebuilt of just toyed with?
Reply #2March 29, 2007, 02:15:19 pm
NOTORIOUS VR
  • 83
« Reply #2 on: March 29, 2007, 02:15:19 pm »
Pump was not rebuilt... it is in perfect working condition, and was just opened to be modified.
No leaks at all.
It's currently still on the car and running.
Reply #3March 30, 2007, 02:50:15 pm
Re: FS: Lots of 1.6L TD Parts - Pump, Block, Internals, etc.
« Reply #3 on: March 30, 2007, 02:50:15 pm »
Quote from: NOTORIOUS VR
- Block w/ crank, pistons, conrods, oil/vacuum pump, etc...  all in great shape, approx 250k - $200
- Intake Manifold w/ disabled BOV (holds 28 psi no problem) - $75
Why the heck are all the deals in Canada?
I need a block inthe states.....
Reply #4March 30, 2007, 05:58:14 pm
addautomotive
« Reply #4 on: March 30, 2007, 05:58:14 pm »
Quote from: "zukgod1"
They are relatively plentiful here. Too bad shipping is so expensive; I've shipped turbos and IPs as far as california, but a block would cost a fortune.
Reply #5March 30, 2007, 08:11:54 pm
« Reply #5 on: March 30, 2007, 08:11:54 pm »
$700 is the cheapest I've found for shipping a block to Utah, mind you I did get a quote from the same company and it was only $300 to ship a complete engine :?
Luckily shipping a head is only like $50 in shipping
Reply #6April 02, 2007, 05:09:49 pm
« Reply #6 on: April 02, 2007, 05:09:49 pm »
I know we could get it here for less than $700.00. Heck I have carriers comming across the border all the time. They are usually full however.
Reply #7April 21, 2007, 10:37:15 pm
NOTORIOUS VR
  • 83
« Reply #7 on: April 21, 2007, 10:37:15 pm »
bump!
Reply #8June 02, 2007, 07:34:21 am
NOTORIOUS VR
  • 83
« Reply #8 on: June 02, 2007, 07:34:21 am »
bump!!! NEW PRICES, EVERYTHING UPDATED!
Reply #9June 02, 2007, 11:48:45 am
blkboostedtruck
  • 1535
« Reply #9 on: June 02, 2007, 11:48:45 am »
would you sell the TD cluster w/tach for 50 us dallars ? the tach is the only part i can use ! i live in the states and we drive by MPH so the metric speedo has no value to me! thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #10June 02, 2007, 03:07:46 pm
Turbinepowered
  • 1206
« Reply #10 on: June 02, 2007, 03:07:46 pm »
What's the ratio printed on the bottom of that TD cluster's tach? 970, or 975? Something different?
I might have use for the Km/hr speedometer from that turbo cluster, if it's the right ratio. Converting a car to km/hr, since I can do the conversion in my head without much problem and the single-unit speedometers seem so much cleaner in my opinion.
Reply #11June 03, 2007, 04:35:51 am
red64chevelle
  • 67
« Reply #11 on: June 03, 2007, 04:35:51 am »
Interested in the IP.  I'll send a PM.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
Reply #12June 03, 2007, 09:52:04 am
NOTORIOUS VR
  • 83
« Reply #12 on: June 03, 2007, 09:52:04 am »
Quote from: blkboostedtruck
No sorry... $50 is not enough
Reply #13June 03, 2007, 09:52:43 am
NOTORIOUS VR
  • 83
« Reply #13 on: June 03, 2007, 09:52:43 am »
Quote from: Turbinepowered
The ratio on the bottom of the speedo is 950.
Reply #14June 03, 2007, 11:54:58 am
Turbinepowered
  • 1206
« Reply #14 on: June 03, 2007, 11:54:58 am »
Quote from: "NOTORIOUS VR"
Ah, nevermind then. I already have two 950 ratio metric speedometers. Keeping my eye out for a 1060 ratio... since once converted that should coincide with my 1707 Syncro speedometer.
Oh, and just a tip, if you click the "Disable HTML in this post" option checkbox, quotes will work properly. Just in case you didn't know.
