Author Topic: Weird head repair  (Read 4435 times)
March 26, 2007, 05:43:43 pm
bvolks73
  • 183
Weird head repair
« on: March 26, 2007, 05:43:43 pm »
Anyone ever see a head repaired like this? I picked it up off my neighbours running Rabbit that they had left water in all winter and had frozen solid. Was going to overhaul it and put it on my Jetta until I saw the weld around #1 injector hole.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #1March 26, 2007, 06:55:40 pm
AdAm84
Weird head repair
« Reply #1 on: March 26, 2007, 06:55:40 pm »
as long as every thing is i nthe right place i wouldn't worry. i was just talking an engine builder today about an aluminum head for a chrysler 2.5L turbo that had cracks. he said that aluminum heads can be welded and repaired. they do that alot to the super expensive brodix racing heads. but i wouldn't worry about that fix as long as it was done by a pro and didn't block off any coolant passages or stuff.
Reply #2March 26, 2007, 08:09:26 pm
Doug
Weird head repair
« Reply #2 on: March 26, 2007, 08:09:26 pm »
I wouldn't worry about it. My IDI TD has a similar repair that has withstood the test of time.
Reply #3March 27, 2007, 09:55:06 pm
Weird head repair
« Reply #3 on: March 27, 2007, 09:55:06 pm »
did you clean around the injector hole??? looks pretty damn clean!
if you didn't clean it, then judging by the other holes... i'd say that there was no leakage from that hole.  so it must be good to go!
similarly, i have a little crack like that one on a parts car that i have just acquired.  hmmm looks pretty bad.
can a 'surface' crack be welded with the injector still in the head???  i dont know much about welding aluminum.  i know cast has to be fully heated.. thats about it.
Reply #4March 28, 2007, 05:03:12 am
Doug
Weird head repair
« Reply #4 on: March 28, 2007, 05:03:12 am »
If I were doing the welding then I would leave the injector in the head just to make sure that the hole and threads did not get warped. Some might try on the car (depends on which injector needs work), but I would remove the head so that I could do the weld in the horizontal position without having to work around all the other stuff.
