Author Topic: too much air?  (Read 6718 times)
March 26, 2007, 05:41:34 pm
vegfuel
  • 125
too much air?
« on: March 26, 2007, 05:41:34 pm »
Has anyone here ever experienced over revving caused by to much air in the fuel lines?
1986 Golf WVO converted.
Reply #1March 26, 2007, 06:54:12 pm
tSoG-84bit
  • 188
too much air?
« Reply #1 on: March 26, 2007, 06:54:12 pm »
now I am no professional, but air in the fuel lines causes negative problems in the other direction, sputtering, loss of power, stalling, are all things that happen when you have air in the fuel lines. excessive blow by, or maybe a bad injector pump seem more probable. If the fuel screw is turned up too high, I believe you can have problems with your car running away as well. I can't say for sure, because I couldn't even pinpoint my own problem with overrevving. A mechanic did a compression test and it was OK, but my injector pump was junk. Sorry you are going through it, but trust me, you aren't the only one.
tSoG
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #2March 26, 2007, 07:01:54 pm
AdAm84
too much air?
« Reply #2 on: March 26, 2007, 07:01:54 pm »
yeah air in the lines wouldn't cause reving and such. it would cause sputtering and rough idle problems.
Reply #3March 27, 2007, 11:39:42 am
vegfuel
  • 125
too much air?
« Reply #3 on: March 27, 2007, 11:39:42 am »
Well she starts great every time, so I would think that the compression is fine. In which case I might not have excess blowby. I even talked to a diesel mechanic and he said that air in the fuel can cause high rev.
Reply #4March 27, 2007, 02:12:22 pm
saurkraut
  • 904
too much air?
« Reply #4 on: March 27, 2007, 02:12:22 pm »
Try disconnecting your breather hoze from you air cleaner and go for a drive.  If you don't have runaway then, you have bad rings and its rebuid time.
If its fully warmed up and you're still getting white smoke, your engine is drinking from its oil pan.  Does its smell like burned engine oil?  If it walks like a duck, quacks like a duck, and smells like a duck, its a duck.
i have a hard time believing air bubles in your fuel line would cause a runaway.  Going to have to raise the BS flag on that one.  Causing uneven running maybe.  But bubles in the fuel line, going to an extreme, means less fuel going into the engine.  Less fuel=less power.  Heck, most volks on here (mysef included) are trying to put more fuel in to get "high revving".
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5March 27, 2007, 07:11:38 pm
too much air?
« Reply #5 on: March 27, 2007, 07:11:38 pm »
yea... rediculous myth busted.
your injectors require around 130 bar (non turbo) and 150 bar (turbo) pressure to open.  when there's too much air inside the pump, the plunger will try to compress the fuel, but there is no fuel, so it tries to compress air, which the pump was never designed to do.  therefore the extreme pressures are not built up, and the injector does not open which means that the engine *should* idle rough or stall out.
i think the only way would be a leaky injector causing runaway... it would have to be severely bad though!
Reply #6March 27, 2007, 09:41:59 pm
too much air?
« Reply #6 on: March 27, 2007, 09:41:59 pm »
Quote from: vegfuel
NO.
 Not even a little bit.
Reply #7March 27, 2007, 10:52:25 pm
  • 2932
air
« Reply #7 on: March 27, 2007, 10:52:25 pm »
Not in a VW but the local bosch pump rebuilder said folks with diesel trucks were getting high revs when air was in the fuel.
 We were talking about problems with air in the fuel system on my VW and he mentioned the result air in the fuel has on certain other vehicles.
Reply #8March 28, 2007, 06:37:43 am
saurkraut
  • 904
too much air?
« Reply #8 on: March 28, 2007, 06:37:43 am »
Jeez, thats just goes against everything i've seen with regards vw diesel engines, and I've seen alot, including the good, the bad and the ugly.
If you can, find out what type of engine and injection pump this high revving with fuel bubbles phenom happens.  Also, the theory on why this happens.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9March 28, 2007, 06:05:49 pm
Re: air
« Reply #9 on: March 28, 2007, 06:05:49 pm »
Quote from: "fatmobile"
that almost sounds to me like a computer related problem... such as the computer trying to compensate for a rough idle due to air...  were they mechanical pumps???  sounds very odd to me!  bubbles of hydrogen maybe??  :twisted:   :lol:
Reply #10March 29, 2007, 09:21:20 am
clbanman
  • 705
    Cambridge, Ontario
too much air?
« Reply #10 on: March 29, 2007, 09:21:20 am »
We have had occasional problems with air in the fuel lines in our trucks, and NEVER had runaways or high idle speeds as a result.  I know diesels can run very lean, but less fuel (than optimal for given load/throttle position) can't possibly increase power.
Calvin
91 VW Golf 1.6NA 5spd
