Author Topic: Injection Pump Tuning  (Read 3650 times)
March 22, 2007, 08:17:20 am
Justin
  • 455
« on: March 22, 2007, 08:17:20 am »
I have just gotten my TDI running and I am having some tuning issues, hear is the current setup
1.9 TDI minus the turbo right now since its in the rebuild stage so I am running it naturally aspirated until I can get the money to rebuild the turbo
1.6 L IDI NA injection pump with TDI camplate and plunger head
I think that my fuel return line is cloged or partially cloged
and the tuning problem is that after running a little while the engine goes into run away because of to much fuel and I cannot find a happy medium for tuning its either to much fuel or not enough
any suggestions?
Thanks
Justin
www.archeryprostaffmi.com
Reply #1March 27, 2007, 07:24:35 am
Justin
  • 455
« Reply #1 on: March 27, 2007, 07:24:35 am »
come on no one has any advice?
well I pulled the govenor mod out so that the run away problem is taken care of, now I need to get the thing to idle, it runs great in the upper rpm's but when I try to get it to idle below about 1300 it just stalls out, or goes into a horrible 5-600 rpm idle
any suggestions on adjustments to the pump.
later
Justin
Reply #2March 27, 2007, 08:14:40 am
Powjetta
  • 152
    San Diego CA
« Reply #2 on: March 27, 2007, 08:14:40 am »
You are doing something that not many of have exerience in, but you might try the IDI forum same question.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
