nozzles
Topic: nozzles (Read 4198 times)
March 19, 2007, 11:24:58 pm
Zulfiqar
nozzles
March 19, 2007, 11:24:58 pm »
Hi,
what nozzles come in the 1.6 NA hydro head, when I opened up my injectors, they had mercedes 240 nozzles in it, while I have come to know that the 1.6 hyd head motor is supposed to use SD265 nozzles.
any help on that - and as bosch are getting very rare now, what other replacements are good.
Diesel IS the future
March 27, 2007, 04:41:05 am
jannemann
Newbie
nozzles
March 27, 2007, 04:41:05 am »
Hallo,
I would advise DNO SD 297 or 273.
These are pre-injection nozzles, buildt in early AAZ and 1y engines. They are phantastic so-called "whispering nozzles".
Jan
sorry for my english
April 08, 2007, 01:29:08 pm
Zulfiqar
nozzles
April 08, 2007, 01:29:08 pm »
I came across this ancient looking guy with a small diesel shop who installed a set of ND denso nozzles in the golf's injectors he cross referenced to the bosch items. Did a half hour job on my pump . DAMN this thing runs like burnt cat now. :twisted:
Ive only got slight hazy smoke till 3/4 throttle and dark grey smoke at WOT
The guy said they are for some yanmar engine - but the 1.6 NA requirements are fulfilled by it.
Im also noticing less diesel rattle at idle but the speed seems to "hang" when decelerating, even when coming to a stop it will "release" to idle after a second. He says to forget it, because the nozzles flow more than stock.
April 08, 2007, 02:05:40 pm
jackbombay
nozzles
April 08, 2007, 02:05:40 pm »
With the smoke you have and the "hanging idle" it sounds like you could use a little turn (loosen) on the screw wit the 13mm lock nut, I had the same issue with a hanging idle lately. You probably only need an 1/8th turn, it is a very sensitive screw, this will reduce smoke at WOT and make the car a little slower though.
Quote from: "burn_your_money"
Turn this screw in 1/4 turn and see what happens
You need to loosen the 13mm lock nut
April 10, 2007, 03:02:00 am
Zulfiqar
nozzles
April 10, 2007, 03:02:00 am »
it helped the hanging idle but I lost power, I took the car to the pump repair technician - he readjusted the pump lever and power screw - it doesnt hang now - now it just releases its rpm from like 1000 to 850 (just guessing) after a second when I come to a stop.
April 23, 2007, 12:09:53 am
Zulfiqar
nozzles
April 23, 2007, 12:09:53 am »
The nozzle part number is 093400-3310
I think they are equivalent to the SD297 nozzles and they are extremely quiet - any nozzle gurus??
April 23, 2007, 03:33:43 am
Zulfiqar
nozzles
April 23, 2007, 03:33:43 am »
btw the nozzle make is denso
nozzles
