86 Golf Diesel 5-speed I lost my #1,#2,#5 Gears- Help Please
Topic: 86 Golf Diesel 5-speed I lost my #1,#2,#5 Gears- Help Please (Read 4865 times)
March 19, 2007, 06:28:13 pm
mtnbob
March 19, 2007, 06:28:13 pm »
I've been working on my new 86 golf, and as i was driving it today, the shifter got even more loose than when i got it a few days ago. i lost the ability to shift from 4th to 5th. i then realized i only had 3rd and 4th gear, and had to limp it home. any ideas? i was told by a friend when i got the car that the shifter on these cars is kinda sloppy, but obviously something has loosened up or broken. I'm going to look at it as soon as the sun come up, but not sure what i'm looking for.
thanks
mtnbob :shock:
86 VW Golf 1.6 N/A 4-door (soon to be turboed!!!)
http://farm4.static.flickr.com/3248/2598033828_d3d19f9842.jpg?v=0
96 Subaru Outback Wagon
March 19, 2007, 07:15:43 pm
March 19, 2007, 07:15:43 pm »
something probably popped off
March 19, 2007, 07:25:14 pm
mtnbob
March 19, 2007, 07:25:14 pm »
lol ok that narrows it down :roll:
March 19, 2007, 07:32:01 pm
craiggroombridge
User+
March 19, 2007, 07:32:01 pm »
the shifter is connected by 2 seprate platic links to the trans one link is the range( r-12-34-5) and the other beeing gear (1-2,3-4,). Check weather these links are in place (neer the fire wall) under the coolant expansion Tank, if these are good then you broke the shifter tube, :cry:
that is a lot more work trust me I know
My first was an 85 gas fun
my second is an 86 gas more fun
my third is a 92 n/a diesel project
March 19, 2007, 07:55:02 pm
Powjetta
San Diego CA
March 19, 2007, 07:55:02 pm »
One of the plastic links broke in your shifter system. It has happened to me before and I fixed mine with a small screw and ordered the metal parts from Roger Brown. You can do that or order the plastic one from VW, but its not too bad to get too and change out. I believe it is the short one closer to the wheel.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
March 19, 2007, 09:02:10 pm
mtnbob
March 19, 2007, 09:02:10 pm »
were the metal linkage parts hard to replace?? i see a webpage that sells metal replacement linkage arms.
March 19, 2007, 11:12:07 pm
March 19, 2007, 11:12:07 pm »
its easier than shifting without em.
March 20, 2007, 03:52:56 am
mtnbob
March 20, 2007, 03:52:56 am »
:mrgreen:
March 20, 2007, 07:50:03 am
dieselsnowmobile
March 20, 2007, 07:50:03 am »
I broke that same plastic link on my brothers Jetta. What seems to happen is that one of the ends breaks off, so I reinforced it with some wire to keep the tension off of the weak plasstic ends and drove 300 miles back home with no problem. We eventally fixed it back to a new stock plastic piece. I still carry that old piece with some wire incase it happens to my Jetta.
The best part is that atleast VW designed the transmission to center in the 3rd and 4th gear columns, otherwise, if it centered in the 1st and 2nd column, it would be much slower limping it anywhere.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
March 20, 2007, 09:09:38 am
March 20, 2007, 09:09:38 am »
yea those little plastic balls look really brittle.. i can't wait to install the newer type linkage. (its basically 2 lines going to the tranny, no arms to break or anything)
March 20, 2007, 09:31:33 am
mtnbob
March 20, 2007, 09:31:33 am »
Thanks you guys nailed it!!! the short connector broke off at the end. i just ordered a shift linkage rod and bushing kit from ebay for 14 bucks.
Reply #11
March 20, 2007, 09:53:31 am
Reply #11 on:
March 20, 2007, 09:53:31 am »
in the meantime i'm pretty sure you could use some duct tape... lol
Reply #12
March 20, 2007, 11:58:36 am
mtnbob
Reply #12 on:
March 20, 2007, 11:58:36 am »
i could definitely rig it but i'm parking it till the new parts come back to the subaru
Reply #13
March 20, 2007, 03:18:54 pm
Powjetta
San Diego CA
Reply #13 on:
March 20, 2007, 03:18:54 pm »
The metal links are just as easy to put on as the plastic, and are adjustable to help center the shifting. I bought the links and some bushings for $48 or so IIRC.
Reply #14
March 20, 2007, 06:16:14 pm
AdAm84
Reply #14 on:
March 20, 2007, 06:16:14 pm »
where did you get the metal linkage pieces at? i recently replaced mine and thought they looked pretty weak.
