Author Topic: 1.6TD higher performance build  (Read 6149 times)
Reply #15March 21, 2007, 05:57:37 am
rabbit GTI/GTD
  • 58
« Reply #15 on: March 21, 2007, 05:57:37 am »
would a 12 mm for a TDI work, the 98 style?? is the 1.9 td pump head bigger than a 1.6. i have one of those pumps
Reply #16March 21, 2007, 09:16:27 am
mdonau
  • 53
« Reply #16 on: March 21, 2007, 09:16:27 am »
Quote from: rabbit GTI/GTD
no, 1,6 and 1,9 TDs have 9mm plungers, but the camdisk ist different: 2,2 vs. 2,6mm lift-heigt.
better are camdisk & plunger from a pump off an Iveco 2,8TDI: 3,6mm & 12mm plunger :) should be good for 200HP+ ;)
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #17March 21, 2007, 04:29:37 pm
Tintin
  • 1279
« Reply #17 on: March 21, 2007, 04:29:37 pm »
1.6D/TD came plate have 2.2mm lift and some profiles, different HP engine.
1.9TD 1993-1995 have 3.2mm lift (firts satge inj. 150Bar), and 1995 and up 2.8mm lift (first stage inj. 130Bar)
If you want a heavy pump, I that can build you.
Reply #18March 24, 2007, 02:02:36 pm
rabbit GTI/GTD
  • 58
« Reply #18 on: March 24, 2007, 02:02:36 pm »
going to pick up my new car(84 rabbt GTI) tonight, :D , i'll post some pics of it, if someone could tell me how i do it, lol, thanks
