Author Topic: 1.6 na crank pulley and poss. injector pump wanted  (Read 4443 times)
March 17, 2007, 07:47:12 pm
dittohead
  • 8
« on: March 17, 2007, 07:47:12 pm »
I need a crank pulley for my 1986 1.6 na diesel jetta.  A local VW wrecker says there is two different ones that year, and the only part left of mine is the mounting flange, so i have no part #  If someone has one they can spare, it would be very much appreciated.
I also would like to grt my hands on a known good injector pump for the same car.  You can PM me or email [email protected]  Im located on Vancouver Island B.C.
Thanks
1986 1.6 NA diesel jetta
Reply #1March 17, 2007, 11:23:02 pm
duffer
  • 164
« Reply #1 on: March 17, 2007, 11:23:02 pm »
Are you referring to the crank gear
  (sometimes calles a toothed pulley)
  or the alternator/water pump pulley?
  If you need the crank gear, you can
  get one, new, from Python Parts
  part #5010-63374 for $18.04 (Cdn).
  If your referring to the alternator pulley,
  contact burn_your_money on this forum
  he may have one.
  He seems to have a lot of things (and,
  occasionally, stuff) for Mk2 Diesels.
Reply #2March 18, 2007, 04:34:07 am
« Reply #2 on: March 18, 2007, 04:34:07 am »
the only difference in 86 was half way through they switched to a hydraulic lifter engine.
did they really change pulley's when changing to hydro???
Reply #3March 18, 2007, 07:22:45 pm
dittohead
  • 8
« Reply #3 on: March 18, 2007, 07:22:45 pm »
Sorry, im looking for the crank pulley that the alt. belt rides on, NOT the crank gear for the timing belt.  I doubt the pulleys would be different, but i dont know for sure.  All i know is that the local "experts" have dragged this on long enough(2 weeks), and i need to get this car going.
Reply #4March 20, 2007, 07:28:58 am
houseofdiesel
  • 210
« Reply #4 on: March 20, 2007, 07:28:58 am »
There are two different types, with AC or without. The AC crank pulleys have a rubber ring in them and much bigger/heavier, the non ac pulleys are just simple steel. You need the right one in order for the vbelts to line up right. I should have both, find out which one you need.
Greg
Reply #5March 20, 2007, 07:46:39 am
dittohead
  • 8
« Reply #5 on: March 20, 2007, 07:46:39 am »
Mine has no A/C or PS.  Just a plain single groove pulley.
