Author Topic: 91 TD part out  (Read 9085 times)
March 13, 2007, 06:34:08 pm
91 TD part out
« on: March 13, 2007, 06:34:08 pm »
Complete engine less oil filter flange, head, alternator, cluster, engine wiring and injectors.
1.6l engine
basically 300-400k kms, 300PSI in cylinder #1 and #4, didn't bother to check the others. The car ran ok considering the compression.
4S tranny, only tested in R and 1 - $100
non leaking pump (for now anyways) - $SOLD
turbo - made a whining noise at idle, for parts only - $40
Manifolds - $pending
Turbo lines - $pending
Pan - $pending
Block - $75 Haven't pulled the head so I don't know what overbore if any it's at. Will separate
Intake hoses - everything except the snorkel $40
Massive starter - $10 - wasn't cranking the fastest, very corroded terminals on battery plus I don't know how good the battery was
Interior bits  $very cheap
PS setup - $100 will separate
AC lines/condenser/rad $10 a piece, lines are $5 or free with other AC purchase
Alt bracket - AC or NON $30
Hard injector lines - $25 for the set
If you can think of anything else that is on a TD I have it so just ask
Delivery is available to the GTA+kitchener on March 24/25
Everything sold as-is
Reply #1March 14, 2007, 07:23:22 pm
91 TD part out
« Reply #1 on: March 14, 2007, 07:23:22 pm »
Dang Tyler, I wish I could find cars like you do.
I think I found a turbo block today, there is a head also. Is there a way to tell a differance between the NA and turbo heads?
Getting closer to needing turbo stuff.
Reply #2March 14, 2007, 10:05:14 pm
91 TD part out
« Reply #2 on: March 14, 2007, 10:05:14 pm »
Quote from: "zukgod1"
what year??? i believe that all hydraulic heads are turbo.  At least the part #'s match up on ETKA...  maybe the earliest hydraulics are not...
Reply #3March 15, 2007, 02:10:37 am
91 TD part out
« Reply #3 on: March 15, 2007, 02:10:37 am »
lol most people do, I have 7 TDs right now :lol:  :shock:  :roll:
Move to Canada, it's all I can recommend.
I've heard the 'all hydros are turbo" bit as well, I'd put TD valves in it though because I'd imagine they'd be different
Reply #4March 15, 2007, 07:43:43 am
91 TD part out
« Reply #4 on: March 15, 2007, 07:43:43 am »
The only problem I have is the head I have is a hydro and the turbo block I found is not.
I belive I read somewhere you can use a solid lifter head on a hydro block by blocking the oil port, but obviously using a hydro head on a non hydro block just wont work. correct?
Reply #5March 15, 2007, 04:10:22 pm
Black Smokin' Diesel
  • 656
Re: 91 TD part out
« Reply #5 on: March 15, 2007, 04:10:22 pm »
I'll take it if it's a K24 with a working wastegate and a good condition compressor wheel.
Reply #6March 16, 2007, 02:01:21 am
91 TD part out
« Reply #6 on: March 16, 2007, 02:01:21 am »
That combination won't work unfortunately.
Reply #7March 16, 2007, 10:39:06 am
91 TD part out
« Reply #7 on: March 16, 2007, 10:39:06 am »
Quote from: burn_your_money
Quote from: zukgod1
That's exactly what I was getting at Tyler. Non hydro head on a hydro block is fine but the otherway isnt feasable.
Reply #8March 16, 2007, 11:03:02 am
Slave2School
  • 531
91 TD part out
« Reply #8 on: March 16, 2007, 11:03:02 am »
Is it a 1.9TD?  I'm looking for a cheap cam that isn't too worn.  I'd like experiment with one in my TDI at some point since I don't think a custom one is in the books after the new pump/lifters/starter I just bled for.
2002 ford focme wagon
Reply #9March 16, 2007, 12:22:04 pm
91 TD part out
« Reply #9 on: March 16, 2007, 12:22:04 pm »
It is a 1.6. I'll hopefully be getting to my 1.9 later this month
Reply #10March 16, 2007, 04:17:52 pm
bernefj60
  • 18
91 TD part out
« Reply #10 on: March 16, 2007, 04:17:52 pm »
hit me offline for details on the lot.
Rob
Rob
Alexandria, VA
Reply #11March 16, 2007, 07:04:45 pm
91 TD part out
« Reply #11 on: March 16, 2007, 07:04:45 pm »
do the 1.9 manifolds fit the 1.6 heads?
Reply #12March 17, 2007, 09:43:03 am
91 TD part out
« Reply #12 on: March 17, 2007, 09:43:03 am »
Yes and no. They bolt up but the intake manifold on the 1.9s are D shaped and the 1.6s are 0 shaped. I've heard the 1.9 intake is an upgrade for the 1.6 but who knows. The exhaust manifolds are the same
Reply #13March 17, 2007, 10:58:40 am
91 TD part out
« Reply #13 on: March 17, 2007, 10:58:40 am »
I've never heard any success stories for hydro heads on solid blocks
Reply #14March 17, 2007, 03:39:49 pm
91 TD part out
« Reply #14 on: March 17, 2007, 03:39:49 pm »
I  thought that there would be pressure issues for the lifters
