Author Topic: Improved breathing needed  (Read 2736 times)
March 10, 2007, 06:50:18 pm
Kudagra
  • 738
    • www.no-coast.com
« on: March 10, 2007, 06:50:18 pm »
Im sure Dave is real busy but Id like to see (another) thread dedicated to those manifolds.
How about a ball park figure? Can I get an advanced prototype? PICTURES PICTURES PICTURES!!!
:D
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #1March 10, 2007, 08:22:43 pm
SMOKEYDUB
  • 630
« Reply #1 on: March 10, 2007, 08:22:43 pm »
RARARARARARARAARARARARARARARARAA **random noise**
 I second that! Need some info!
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2March 16, 2007, 03:11:05 pm
MaxHedrm
  • 114
    • blog
« Reply #2 on: March 16, 2007, 03:11:05 pm »
Quote from: SMOKEYDUB
What's wallawallawallawallawalla.  :wink:
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #3March 17, 2007, 11:29:09 am
935racer
« Reply #3 on: March 17, 2007, 11:29:09 am »
Guess I'll have to take some more pictures. I'll try and do that this week. I have a budget intake manifold utilizing the stock intake manifold, for around $350, which I would recommend to anyone wanting to get into tuning their vw turbo diesel. The tubular exhaust manifolds are a lot more expensive, looking at around $900 after they are all ceramic coated and everything. I'll try and get some pictures and info for each manifold up here soon.
PS Kudagra, I still have you lightened flywheel sitting here!
Reply #4March 17, 2007, 12:21:16 pm
subsonic
  • 1836
« Reply #4 on: March 17, 2007, 12:21:16 pm »
Dave,
What can you tell me about the stock manifold you are modifying. Is this stock off the vw diesel or a higher performance part off another vw application?   What kind of improvments / benefits will this offer over the stock application?  Before and after if you will.  Is this something you can test with your flow bench and measure the difference?  Do you have any flow numbers or figures for combined sets of your products, Say if someone had you install your cam, do the port and polish on the 1.9 head, combined with this manifold and your downpipe?  If this package was put together with the availability of more fuel-Giles pump-and going onto a completly rebuilt bottom end, where would that leave us with the turbo?  I saw in one of your previous posts that you said you would not go any higher than the stock t3 with the .48 hot side for anyone running a non ported head.  With the above mentioned combo, what would you consider for turbo sizing / setup? A t3 or k24 hybrid or something bigger?  This would be on a daily driver that will spent 80% of its life at highway speeds, 80 to 130kph.  Of course a whole lot of opportunity for fun happens below those speeds  :)  What say you sir?
