Author Topic: Glow Plug Help  (Read 4523 times)
March 08, 2007, 04:55:13 pm
79Rabbit
Glow Plug Help
« on: March 08, 2007, 04:55:13 pm »
Im my last post I was having trouble getting my 79 Rabbit to kick over and had white puffy smoke come out when i first start the engine, and darker smoke when i start the engine when its warm.....  Well I took it apart and found that the Cylinder #1 had the tip of the glow plug broken off.  Anybody have any ideas on how this may have happened? Also whats the best way to fish out that glow plug tip?  I know is gotta be in there somewhere......  Thanks!
Reply #1March 08, 2007, 09:15:41 pm
tylernt
  • 344
Glow Plug Help
« Reply #1 on: March 08, 2007, 09:15:41 pm »
Glow plugs can be burned by a bad injector, or by a malfunctioning glow plug relay that makes them stay on too long / all the time.
If it's just the one plug that got burnt, then that injector probably needs rebuilt. Hope you kept track of which injector was on that cylinder. ;)
I think I paid about $40 per injector rebuild from the local Bosch shop (that includes new a nozzle). No need to do all 4 if your other 3 glow plugs are fine.
White smoke can be an indication of over advanced timing, so once you fix the injector and the glow plug, you might get the timing checked if it still blows white smoke on startup.
Reply #2March 08, 2007, 09:49:14 pm
Glow Plug Help
« Reply #2 on: March 08, 2007, 09:49:14 pm »
black smoke on startup may also be an indicator of bad compression.. or possibly bad injector, but usually blue smoke is an injector.  sometimes hard to differentiate colours... blue is almost a white & blackish blue haze... hmmm confusing isnt it? lol
Reply #3March 08, 2007, 10:37:27 pm
79Rabbit
Crud..... I had a feeling the injector may have gone bad....
« Reply #3 on: March 08, 2007, 10:37:27 pm »
That sucks if the injector went bad..... what about the Missing glow plug tip? whats the best way to fish that out? Also Whats the best way to test for a bad injector? any ideas? Thanks!
Reply #4March 08, 2007, 10:52:18 pm
tylernt
  • 344
Glow Plug Help
« Reply #4 on: March 08, 2007, 10:52:18 pm »
Testing the injector involves some specialized shop equipment, so unless you're really into diesel tech stuff it's not really feasible to do it yourself. Best home test for a bad injector is if it damages glow plugs. ;)
If the glow plug tip is not visible via the injector hole, then it probably fell down into the cylinder and got pulverized between the piston and the cylinder head. So there may be some loose debris in there. Someone else more knowledgeable than I can comment if they would be soft enough to be harmless or if you should try to blow them out with compressed air. Hopefully it would not be necessary to pull the head off.
Reply #5March 09, 2007, 09:49:49 am
79Rabbit
Glow Plug Help
« Reply #5 on: March 09, 2007, 09:49:49 am »
Hey thanks guys! I Ordered some new glow plugs last night with a new relay.... Im going to pull out that injector and most likely replace the whole thing, not sure yet still have to check prices.  Thanks for the help guys!
Reply #6March 09, 2007, 10:00:28 am
tylernt
  • 344
Glow Plug Help
« Reply #6 on: March 09, 2007, 10:00:28 am »
Sounds great. Don't forget to get a new injector heat shield (washer that goes in the bottom of the injector hole), as they are not re-usable. Make sure it's right-side up, too.
When loosening the injector, only go forward a quarter of a turn at a time and then back off a bit. Also, never pull towards the front of the car, always push towards the back of the car. The injector bosses in the cylinder head have been known to crack if you pull.
Don't let me scare you though, you'll be fine. :)
Reply #7March 09, 2007, 03:15:03 pm
79Rabbit
Glow Plug Help
« Reply #7 on: March 09, 2007, 03:15:03 pm »
Hey you guys wouldnt happen to know of the best place to get those injectors would ya?  Cheapest i found them was $36.95 with a $11.00 Core charge.  Know of anyplace cheaper?
Reply #8March 09, 2007, 03:33:59 pm
tylernt
  • 344
Glow Plug Help
« Reply #8 on: March 09, 2007, 03:33:59 pm »
$37 is a good price, like I said I paid $40 to have my used ones rebuilt. If there is a cheaper source, I'd like to know about it too!  :!:
Reply #9March 09, 2007, 04:05:12 pm
foxracer1
  • 991
Glow Plug Help
« Reply #9 on: March 09, 2007, 04:05:12 pm »
I would replace a whole set not just one. The other 3 cyls will have old worn out injectors. just my $.02
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #10March 09, 2007, 05:42:48 pm
Glow Plug Help
« Reply #10 on: March 09, 2007, 05:42:48 pm »
If you are in Canada the cheapest I have found so far is http://www.autopartsonlinecanada.com/
sometimes you have to say that you have a 84 rabbit to find injectors
They are around $50 + $20 core IIRC
Definitely replace them in a set, it's like driving with 3 bald summer tires and one winter tire in the snow....
Reply #11March 10, 2007, 07:00:14 am
Glow Plug Help
« Reply #11 on: March 10, 2007, 07:00:14 am »
Reply #12March 10, 2007, 08:45:23 am
pop tester
« Reply #12 on: March 10, 2007, 08:45:23 am »
What was the filter you used in the tee?
Reply #13March 10, 2007, 02:24:54 pm
Fisher
  • 148
Glow Plug Help
« Reply #13 on: March 10, 2007, 02:24:54 pm »
Halsey Import Parts in Portland, Or.  $36
