AAZ engine with K24 turbo
Topic: AAZ engine with K24 turbo (Read 3739 times)
March 07, 2007, 12:18:45 pm
Jimmy Diesel Junior
March 07, 2007, 12:18:45 pm »
Hi all. I've been reading the search forum again and it leads me to another question
When i fit the k24 to the aaz, can i swap over the 1.6td sump onto the aaz and block the oil return at the rear of the block or will the rear engine mounting be in the way of the eturn oil pipe :shock:
PEACE THROUGH SUPERIOR HORSE POWER
March 07, 2007, 01:20:40 pm
mdonau
March 07, 2007, 01:20:40 pm »
simply: yes
but the return line may be a little too short.
greets, michael
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
March 08, 2007, 10:29:14 am
Jimmy Diesel Junior
March 08, 2007, 10:29:14 am »
Ok thanks. So i need to extend the return line a little but there is no issue with the rear engine mounting fouling the return line???
March 09, 2007, 07:40:15 pm
andy2
March 09, 2007, 07:40:15 pm »
I'm not sure about using the 1.6 oil pan on the AAZ.I would have to guess that the AAZ motor mount would not be made for the 1.6 oil line to go between it and the block.I just use the 1.9 return into the block.You will need the upper half of the 1.6 return line and the bottom half of the 1.9 return to make it work without too much hastle.
March 10, 2007, 12:45:35 pm
Jimmy Diesel Junior
March 10, 2007, 12:45:35 pm »
Thanks for the reply Andy. Does anyone else want to add their thoughts on the matter :?:
