Author Topic: Car moved with no Tbelt, thoughts on damage  (Read 4942 times)
March 05, 2007, 01:16:13 pm
flapjack
  • 283
« on: March 05, 2007, 01:16:13 pm »
Timing belt was off and I had to move the car. My buddy started pushing it before I could take it out of gear.  I can't remember if the motor turned or not. I was screaming STOP! freaking out, knocking over children and senior citizens, diving in thru the window to yank on the shifter...
In any case, assuming the car rolled a foot in first gear with no timing belt, when I pull the head off, is there a chance theres damage that isn't visible?
Any thoughts appreciated, thanks
signature
Reply #1March 05, 2007, 01:17:40 pm
g-spec
  • 289
« Reply #1 on: March 05, 2007, 01:17:40 pm »
How far could he have moved it with the car being in gear????
I dont think there would be any damage...but then again Im not 100% sure!!!
Reply #2March 05, 2007, 01:23:22 pm
flapjack
  • 283
« Reply #2 on: March 05, 2007, 01:23:22 pm »
moved about a foot, i think at the most
signature
Reply #3March 05, 2007, 02:15:04 pm
« Reply #3 on: March 05, 2007, 02:15:04 pm »
if there is any damage, its probably not too bad... what gear did you have it in??? 1st gear has a locking safety so the car doesn't roll... if you had it in say... 2nd gear then you could worry a little bit.
Reply #4March 05, 2007, 06:21:51 pm
flapjack
  • 283
« Reply #4 on: March 05, 2007, 06:21:51 pm »
good point, i have no idea what gear it was in. I know it moved a bit tho.
what a dumb ass way to start a project  :roll:
signature
Reply #5March 05, 2007, 11:39:20 pm
« Reply #5 on: March 05, 2007, 11:39:20 pm »
I towed one witht the cam locked, and it ran after.  a lot of revving somewhat straightened the bent valve/s a bit, and it ran even better.
Don't be too afraid 8)
Reply #6March 09, 2007, 10:10:40 am
« Reply #6 on: March 09, 2007, 10:10:40 am »
well if you lock the cam, isn't that the position where the valves stay closed???  that should be fine then
