Author Topic: exhaust questions regarding max performance.  (Read 6493 times)
February 28, 2007, 12:29:31 pm
carrizog60
  • 978
« on: February 28, 2007, 12:29:31 pm »
hello
i have one question that i would like to be answered by using some technical info,not just a "because i think"...
in a turbocharged engine what is the best option for maximum HP?regard that no noise or legal issues are in the line,just max hp in sight
-no exhaust at all?(i see dragster use that)
-exhaust with the same diameter of the turbo manifold?
-exhaust with smaller diameter than turbo manifold?(to create some back pressure)
and what about not just max HP but also low and midrange power?
any differences?
please give me your thoughts and i would appreciate that it was complemented with some technical backup 8)
thank you 8)
Portugal
Reply #1February 28, 2007, 03:08:34 pm
Slave2School
  • 531
« Reply #1 on: February 28, 2007, 03:08:34 pm »
Alex, "What is a 6" pipe through the hood?"
2002 ford focme wagon
Reply #2February 28, 2007, 03:20:06 pm
935racer
« Reply #2 on: February 28, 2007, 03:20:06 pm »
I properly fitted downpipe with a transition right off the turbine with the small end being the same size as the turbine outlet, than transitioning 1" or more from that diameter. :twisted:
Reply #3February 28, 2007, 04:37:18 pm
carrizog60
  • 978
« Reply #3 on: February 28, 2007, 04:37:18 pm »
so on turbos the bigger the better?
doesent any backpressure is needed?
and why is that?
Portugal
Reply #4February 28, 2007, 05:07:50 pm
« Reply #4 on: February 28, 2007, 05:07:50 pm »
you don't want back pressure on a turbo charged car because for one it is completely unecessary because you want backpressure at the manifold, at the head and the actual motor, have a turbo blocking up the ehxaust supplies more than enough back pressure.  so the bigger the exhaust the faster the spool the faster you get moving.  the other thing is also that diesel cam shafts have no over lap, so even on na diesels the bigger the better.
Reply #5February 28, 2007, 05:57:29 pm
SMOKEYDUB
  • 630
« Reply #5 on: February 28, 2007, 05:57:29 pm »
 :D  I can't put a big enough smiley face. That is just mint! LMAO
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #6March 01, 2007, 05:16:58 am
carrizog60
  • 978
« Reply #6 on: March 01, 2007, 05:16:58 am »
didnt understand that 6" post...
Portugal
Reply #7March 01, 2007, 08:13:54 am
veeman
  • 421
« Reply #7 on: March 01, 2007, 08:13:54 am »
Other than the obvious overtones, I'm assuming he meant a short upturned exhaust straight up through the hood like some people do.  Zero backpressure post-turbo, short run of large diameter pipe.
I've got a shot of a Mk4 Jetta drag car with the exhaust pointing right up by the windshield...  Pretty wild.    I doubt you'd want to run that on the street, but I believe there are a few people that are running "straight pipes" under the car without mufflers or resonators.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #8March 01, 2007, 09:29:23 am
carrizog60
  • 978
« Reply #8 on: March 01, 2007, 09:29:23 am »
but dont we need some king of backpressure for the best results?
and what is the size of stock 1.6 td exhaust?
Portugal
Reply #9March 01, 2007, 09:36:19 am
veeman
  • 421
« Reply #9 on: March 01, 2007, 09:36:19 am »
Just as Trev0bor said...
"you don't want back pressure on a turbo charged car because for one it is completely unecessary because you want backpressure at the manifold, at the head and the actual motor, have a turbo blocking up the ehxaust supplies more than enough back pressure"
So...in effect, the turbo supplies the backpressure needed to prevent reversion, etc.   After the turbo, the exhaust can be as free as possible.
On my mk1 TD, the exhaust was probably 1.75" or so at the downpipe.  Probably some metric size.   Now I've got a 2.5" downpipe and exhaust from the turbo back.  Fits fine and isn't loud.  I'm running a Giles pump and 20 psi and I can tell you that the thing runs great.
81 Caddy TD
83 VW GTI FSP
86 4ktq
Reply #10March 01, 2007, 09:37:02 am
BlackTieTD
  • 1512
« Reply #10 on: March 01, 2007, 09:37:02 am »
Quote from: carrizog60
yes. backpressure is provided by the turbo.
IIRC its around 1.5" but not exactly 1.5" as i think it was spec'd in metric.
Reply #11March 01, 2007, 02:23:20 pm
dieselsnowmobile
  • 103
« Reply #11 on: March 01, 2007, 02:23:20 pm »
This is what a 6" pipe through the hood is.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #12March 01, 2007, 02:51:38 pm
BruceM31
  • 64
« Reply #12 on: March 01, 2007, 02:51:38 pm »
that is a very inspiring image!!!  lmao!
Thats not a rod knockin..........its a diesel!
Reply #13March 01, 2007, 04:23:23 pm
mtnbob
  • 738
« Reply #13 on: March 01, 2007, 04:23:23 pm »
LOL :lol:
96 Subaru Outback Wagon
Reply #14March 01, 2007, 04:34:00 pm
carrizog60
  • 978
« Reply #14 on: March 01, 2007, 04:34:00 pm »
:lol:
new giles monster pump? :lol:
Portugal
