Author Topic: who is running SVO without problems??  (Read 3249 times)
February 26, 2007, 08:20:10 pm
superman293
  • 93
« on: February 26, 2007, 08:20:10 pm »
I have a 82 Rabbit that im thinkin about putting a SVO kit on, I have plunty of oil, but Im kinda sketchy about it, anybody else use it will success?? any downfalls??? I was planning on purchasing a kit from grease car, any input or thought would be helpfull
thanks
Reply #1February 26, 2007, 08:42:46 pm
Barry W
« Reply #1 on: February 26, 2007, 08:42:46 pm »
I've heard nothing but good things....
I got a friends dad has it on a 85 mercedes from grease car, he loves it.
Reply #2February 26, 2007, 09:27:09 pm
« Reply #2 on: February 26, 2007, 09:27:09 pm »
Garbage in = garbage out
If you use substandard parts on your conversion, you will have issues.
If you use unclean oil (that is water contaminated, is not filtered, or is too thick) you will have problems.
If you are an idiot, you will have some trouble from that too.
If yo spill, people will come to hate you.
Plastic fittings are bad.
I think thats about it for pitfalls.
In 20+K of grease fueled miles, I've had more problems with aging diesel components than grease problems.
I use about a 50-50 mix of Greasel kit and homebrew stuff, never tried a Greasecar kit.
Before starting, you should know how to swap batteris, and how to prime an engine which has run out of fuel.
I favor leaving the entire OE diesel supply system intact, and adding in a grease fuel system for redundancy.
Reply #3March 02, 2007, 08:39:57 am
jwspin
  • 138
« Reply #3 on: March 02, 2007, 08:39:57 am »
i have installed over 16 kits in cars from vw mercedes and izuzu, they work great. all of the kits i have done are custom except for one greasecar kit on a mercedes. i drove from NY to CO completely on grease except for my startup and purge times which added to less than 2 gallons of diesel. if you are just learning then get a kit, all of the big names are good and they all work. from there on out go through the forums and get ideas on how to customize your own.
forums:
greasecar.com
biodiesel.infopop.cc
jared
Reply #4March 03, 2007, 03:49:15 am
carrizog60
  • 978
« Reply #4 on: March 03, 2007, 03:49:15 am »
here in portugal i am running SVO(new)in the summer at 50% minimum and never had problems.but here even at night the temps dont drop below 15º celcius and hit +30 º easely 8)
Portugal
Reply #5March 03, 2007, 06:45:39 pm
speedy
  • 120
« Reply #5 on: March 03, 2007, 06:45:39 pm »
I am running a blend of up to 70% filtered WVO in my '91 300D.  I was going to do the same with my 1.6TD but I am hesitating now because my dad had problems with his IP (87 Jetta TD) after running WVO blend (in Germany).  His car got very hard to start.  He replaced the IP and things were good again for a while and he started having the same problem again.  A German mechanic told him it was because of the oil.  I also bought a '91 Jetta diesel with a leaking IP that had been run on WVO.
 I would have thought that since the pumps in the VW and Mercedes were both Bosch, they would have worked equally well with WVO.  What I have seen seems to indicate otherwise though.  I will likely try it with my TD once I have secured an extra pump but until then only straight diesel.   :?
Reply #6March 04, 2007, 05:21:14 pm
jwspin
  • 138
« Reply #6 on: March 04, 2007, 05:21:14 pm »
instead of running a blend do it the right way and use a two tank heated system. you wont have problems. veg does eat rubber parts so make sure everything is synthetic. if your seal on your pump starts to go them put in a viton one. its easy...
-jared
