Author Topic: What engine size is this? Pic inside!  (Read 3974 times)
February 26, 2007, 03:27:42 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« on: February 26, 2007, 03:27:42 am »
I need to know what engine this is. The cast nr on the engine block is: CK 441 112 and the head cast nr: 068 103 373.
I believe itīs an 1.6 but need to be sure. And it looks kinda old by judjing from the older style vaacum pump. Itīs from a Passat.
Any info appreciated.
<-- My M-tdi Mazda B-1800 and my other cars
Reply #1February 26, 2007, 03:39:06 am
  • 5104
« Reply #1 on: February 26, 2007, 03:39:06 am »
1.5
Reply #2February 26, 2007, 06:31:53 am
« Reply #2 on: February 26, 2007, 06:31:53 am »
that thing looks pretty ancient... :lol:
Reply #3February 26, 2007, 06:54:33 am
dieselsnowmobile
  • 103
« Reply #3 on: February 26, 2007, 06:54:33 am »
Yep, I second 1.5 L.  Here is a website with most if not all of the engine codes.
http://scirocco.cs.uoguelph.ca/gtd/VW%20diesel%20engines.htm
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #4February 26, 2007, 08:58:19 am
myke_w
  • 1099
« Reply #4 on: February 26, 2007, 08:58:19 am »
the really small oil return on the front of the head gives it away..
Reply #5February 26, 2007, 03:05:58 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #5 on: February 26, 2007, 03:05:58 pm »
I have a vacum pump just like that. I have always thought mine was a 1.6. Maybe i'll have to look. Where are the casting numbers?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #6February 27, 2007, 07:28:44 am
dieselsnowmobile
  • 103
« Reply #6 on: February 27, 2007, 07:28:44 am »
On the block just under the radiator hose coming out of the head.  You will see a flat surface, look for the first two letters.  You may have to shine a flashlight at different angles plus try to clean the surface off with a wire brush or screw driver.
I found this picture that shows where the engine code it.
Reply #7February 27, 2007, 06:36:12 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #7 on: February 27, 2007, 06:36:12 pm »
Ok thank you very much i'll go out there now and check it out.
91 S10 305 TPI T56
Reply #8February 27, 2007, 08:38:07 pm
hipifreq
  • 89
« Reply #8 on: February 27, 2007, 08:38:07 pm »
Definitely a 1.5L based on the CK code, and also definitely out of a Passat as the alternator is not mounted in front of the fuel pump like in the Rabbit and Jetta.
What's your plans for it?
For tech info get a Dasher Bentley manual.
'80 Dasher diesel fastback - currently undergoing engine transplant
Reply #9February 28, 2007, 04:59:22 am
Sierra94
  • 123
« Reply #9 on: February 28, 2007, 04:59:22 am »
Dump it in the nearest river  :lol:
Reply #10February 28, 2007, 05:49:41 am
Turbinepowered
  • 1206
« Reply #10 on: February 28, 2007, 05:49:41 am »
If you were on the same continent as me, I'd say I'd take it.
Reply #11February 28, 2007, 09:53:52 pm
hipifreq
  • 89
« Reply #11 on: February 28, 2007, 09:53:52 pm »
Heck yeah, same here. If nothing else I'd love to get the fuel pump off of it.
If the shipping's not too out of control I'd pay to have the pump sent here to states. I'd love to have an extra for fiddling with before ripping into my own.
