Author Topic: Bought another!  (Read 2165 times)
February 25, 2007, 07:59:45 am
Baxter
Bought another!
« on: February 25, 2007, 07:59:45 am »
:roll:
1991 VW T3 syncro single cab pick up 1.6TD.
Bit of a gnarler at the moment, just come out of service from a potato farmer.
It's sort of been looked after, but sort of left also, done quite a bit in the last week.
Work done.
Cold start cable handle. (Missing)
Big mirrors (new)
Full service. (needed it!)
Gearbox oil change. (minging)
Front diff oil change. (manky)
Clutch. (Slipping)
Free off stiff/sticking release arm.
Spigot shaft bearing. (rough)
Clutch slave cylinder. (rough)
New exhaust manifold to head gaskets. (blown, sheared stud)
New downpipe gasket. (blown)
Radius rod bushes (noisey)
Secure handbrake cables (insecure)
fitted interior light bulb (blown)
Fitted correct 10w rear side light bulbs
Fitted second hand OSR light cluster (smashed)
Fitted 50w reverse lights (trial, poss new product)
Brake and clutch pedal rubbers (missing/worn)
Work pending
Cambelt and tensioner. (belt is shafted)
Pump timing. (just because)
Tappets. (probably never done)
Front discs and pads (discs below minimum thickness)
brake fluid change (as black as you like!)
Secure drivers door bottom hinge/door skin (loose/torn)
Fit CB.
Fit spare wheel to rear of cab.
Fit front fog lights.
Carry out headlamp wiring upgrades.
Fit viscous coupling (bit stiff)
Match up locks onto one key.
Replace rubber steering UJ's.
Better go and update my signature!
 :lol:
Thank heavens for motor traders insurance policies or this little lot would cost me a small fortune!
 :lol:
