Author Topic: New 5 cycle IDI diesel  (Read 5049 times)
February 21, 2007, 10:05:35 pm
itzdshtz
  • 94
« on: February 21, 2007, 10:05:35 pm »
Check this out,rebirth of the IDI?
http://www.diro-konstruktion.de/dieselmotor.html
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #1February 21, 2007, 11:03:49 pm
« Reply #1 on: February 21, 2007, 11:03:49 pm »
Wow, that German crack makes my head spin...
Reply #2February 22, 2007, 03:34:53 am
carrizog60
  • 978
« Reply #2 on: February 22, 2007, 03:34:53 am »
can someone explain in guide lines?
Portugal
Reply #3February 22, 2007, 06:30:45 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: February 22, 2007, 06:30:45 am »
Link to the U.S. patent for the engine:
http://patft.uspto.gov/...
Calvin
91 VW Golf 1.6NA 5spd
Reply #4February 22, 2007, 08:51:26 am
« Reply #4 on: February 22, 2007, 08:51:26 am »
i don't really understand the benefit of that extra rotating assembly... it seems that the injector pre-injects into the small shaft which then is opened into the main combustion chamber... is this supposed to pre-ignite the fuel or something?
it almost seems like the glow plug is pre-igniting the fuel in the small rotating chamber... lots of wear and tear on that gp??? i guess once it gets hot enough it shouldn't need the gp... but still looks to me like just another part to break... and if your injection timing is off... watchout  :shock:  :lol:
very interesting though... maybe makes for easier cold starting too???
Reply #5February 22, 2007, 09:00:06 am
  • 1156
    • Malone Tuning Ltd.
« Reply #5 on: February 22, 2007, 09:00:06 am »
Pretty cool.. one of the PDF file shows a step-by-step diagram of each cycle. It makes sense how it functions.. but like the poster above stated, what are the benefits of this design?? Not enough English in the original link. I'll check the U.S. patent file though, and maybe post a Cliff's Notes here (or someone else can).
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #6February 22, 2007, 10:04:35 am
Slave2School
  • 531
« Reply #6 on: February 22, 2007, 10:04:35 am »
What are they trying to accomplish?  A super high reving diesel design with more complete combustion from more fuel/air burn time?  It looks pretty wacky to me...I wish I could read german.
2002 ford focme wagon
Reply #7February 22, 2007, 12:46:29 pm
Darkness_is_spreading
  • 288
« Reply #7 on: February 22, 2007, 12:46:29 pm »
They are using the rotating combustion chamber in which a portion of the rich mixture is to be burnt, which is then intended to be used as an igniter of a leaner mixture in the larger combustion chamber.
So they in a way are improving the firing efficiency of the motor by burning fuel in a Pre(rotating chamber), then  allowing the preburnt to enter the chamber or lean fuel mix and to help burn that mix.
I would think the possible benefits would be lower CR,  ie less compression of air to ignite the fuel,  run more boost,  lower EGT's,
Reving might be a problem not totally sure,  because not sure if these little rotating combustion chambers would hold up to the heat and crazy rpm........
92 Jetta 1.6 T (Sleepin)
Reply #8February 23, 2007, 04:55:17 am
« Reply #8 on: February 23, 2007, 04:55:17 am »
very interesting concept on a completely enclosed pre-combustion chamber...  but like i said before... improper injection timing can now break your motor  :shock: (if you have this type of motor of course...)
i can see the benefit of better cold starts on this type of setup.  but what would the precombustion chamber be made out of?  what could withstand that much heat/abuse???  from the pics it almost looked as if the diesel fuel was cooling down the alternating combustion chamber...
Reply #9February 23, 2007, 06:25:51 am
MacGyver
  • 245
« Reply #9 on: February 23, 2007, 06:25:51 am »
First thing I thought of was a hundred year old slide-valve engine.
Reply #10February 24, 2007, 07:51:21 am
Dr. Diesel
  • 1341
« Reply #10 on: February 24, 2007, 07:51:21 am »
I think the point of this is to lengthen the uh--dwell period-- in which the air (and fuel) remain in the state of highest compression. Twice as long, by the looks of it. Allowing combustion to occur in a small volume chamber for such a long time (Like our IDI's, but without driving a piston away and immediately reducing the chamber volume) must allow for a higher percentage of burned fuel. That can only mean more power, efficiency, and lower emissions.
The animated diagram shows what appears to be some degree of combustion when the fuel is injected. Perhaps the glowplug is used only for starting, which might be the phase the animation is showing.
This could be the combination of the best of both DI and IDI engines in one. The efficiency of DI with the revability and lower noise/vibration of IDI.
I like it! :D
Tack on that new VW plan of turbo and supercharging, and you've got a winner.
Reply #11February 28, 2007, 01:13:21 am
OM617
« Reply #11 on: February 28, 2007, 01:13:21 am »
It just looks like another big moving part to wear out and cause problems.
