Author Topic: Oil fliter thread size  (Read 3380 times)
February 15, 2007, 08:24:35 pm
foxracer1
  • 991
« on: February 15, 2007, 08:24:35 pm »
So i plan on installing an air to oil cooler. And i would still like to have the water to oil cooler/heater so it still warms up quickly. But i'm unsure of the thread size so that i can purchase a spin on adapter. I plan on installing a remote mount oil filter too because the filter is already close to the radiator as it is. I also plan on installing a thermostat so the air to oil cooler only circulates all the oil above 180.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #1February 16, 2007, 04:36:58 am
« Reply #1 on: February 16, 2007, 04:36:58 am »
I'm also thinking about a remote mount oil filter, it would make life so much easier
Reply #2February 16, 2007, 05:18:06 am
carrizog60
  • 978
« Reply #2 on: February 16, 2007, 05:18:06 am »
i have both oil coolers mounted.
a adapter plate under the stock cooler and the filter.
only issue was that i have to find a oil filter that was half the height of the stock one...
problem solved and now the oil warms quickly and maintains the temp. more steady
Portugal
Reply #3February 16, 2007, 05:22:55 am
thread size
« Reply #3 on: February 16, 2007, 05:22:55 am »
I believe it is the same size as a Ford FL1a filter. The oil cooler adapter I have has a built in thermostat. I didn't have the clearance for the stock cooler in the stock location in my application(Rover), but I put it in up by the remote filter in case I ever want to try pumping water through it for a hot shower while camping.
Reply #4February 16, 2007, 06:42:37 am
foxracer1
  • 991
« Reply #4 on: February 16, 2007, 06:42:37 am »
So which adapter did you buy, I know its metric but im not sure which.
91 S10 305 TPI T56
Reply #5February 16, 2007, 10:18:09 am
carrizog60
  • 978
« Reply #5 on: February 16, 2007, 10:18:09 am »
i have a mocal with thermostat 8)
Portugal
Reply #6February 16, 2007, 01:02:00 pm
foxracer1
  • 991
« Reply #6 on: February 16, 2007, 01:02:00 pm »
I'm sorry to be this picky but do you have the P/N or the thread size?
91 S10 305 TPI T56
Reply #7February 16, 2007, 01:25:35 pm
carrizog60
  • 978
« Reply #7 on: February 16, 2007, 01:25:35 pm »
don't know what you mean... :oops:
tomorrow i will take a pic of my setup :wink:
Portugal
Reply #8February 16, 2007, 01:54:31 pm
Baxter
« Reply #8 on: February 16, 2007, 01:54:31 pm »
3/4 UNF.
Reply #9February 17, 2007, 02:48:36 pm
scopefrfd
  • 289
« Reply #9 on: February 17, 2007, 02:48:36 pm »
I believe it's 3/4 x 16
