Author Topic: engine noise  (Read 3814 times)
November 20, 2004, 04:31:47 pm
akl
engine noise
« on: November 20, 2004, 04:31:47 pm »
I drive a 1.9TD and I'm experiencing a very loud rattle at 2900 rpm. It seems to be coming from the valve train area but I could be wrong. I've recently had the motor apart and everything appeared to be normal. Anyone heard of this before?
Reply #1November 20, 2004, 04:48:40 pm
QuickTD
  • 1156
engine noise
« Reply #1 on: November 20, 2004, 04:48:40 pm »
Did it make the noise before you had it apart?
Reply #2November 20, 2004, 06:06:57 pm
akl
engine noise
« Reply #2 on: November 20, 2004, 06:06:57 pm »
yes, no change in the noise from before to after.
Reply #3November 21, 2004, 06:50:30 am
QuickTD
  • 1156
engine noise
« Reply #3 on: November 21, 2004, 06:50:30 am »
Is your noise present at any other engine speed? If not it seems like resonance. My AAZ had a very bad exhaust resonance at 2800rpm. Get a helper to place their foot on the tailpipe while you rev the engine to the noisy rpm, if the noise goes away you have found the problem. I added a longer flex joint at the downpipe to fix mine. Also get under the car and tap on the catalytic converter with a rubber hammer and listen for rattles. The cat has been known to come apart inside. I don't know what else could vibrate at such a specific RPM.
Reply #4November 21, 2004, 08:56:33 am
akl
engine noise
« Reply #4 on: November 21, 2004, 08:56:33 am »
Thanks for the prompt reply. The noise starts specifically at that rpm, is bad for about 400 rpm then slowly tapers off. It sounds to me more like a mechanical vibration but I will definately check out the exhaust. Thanks
Reply #5December 07, 2004, 01:46:08 am
engine noise
« Reply #5 on: December 07, 2004, 01:46:08 am »
I have an 87 vw golf 1.8 automatic and it always makes a weird noise at about 1800-2000 rpm.  It goes away when the engine rpm is not in that range.  I never liked automatic anyway (except for the laziness) so i just left it and never gave me any problems.  I now drive a 1.6L TD :D and the golf still runs (even though I drove the piss out of it!!!)
