Author Topic: Mix Gasoline and Diesel?  (Read 7798 times)
February 09, 2007, 09:39:32 pm
dlorimer
  • 31
« on: February 09, 2007, 09:39:32 pm »
May be a strange question, but a friend of mine told me that you can put some regular unleaded gas in your diesel fuel to lower the viscosity and keep it from gelling.  Is this accurate?  If so, how much per 15 gallon tank?
Reply #1February 09, 2007, 10:20:14 pm
« Reply #1 on: February 09, 2007, 10:20:14 pm »
only for emergencies... just buy a good anti gelling additive from the store.  gas isnt a really good lubricant...  very stupid to mix gas with diesel if you ask me... unless you were stranded and thats all you had to un-gel the diesel oil.
Reply #2February 09, 2007, 11:37:17 pm
rabbid79
  • 684
« Reply #2 on: February 09, 2007, 11:37:17 pm »
I remember in the Rabbit owner's manual it talked about mixing something like 10% gasoline with diesel to help keep from geling.  Might be better to do with #2 diesel instead of #1.
'15 WRX
Reply #3February 10, 2007, 03:42:27 am
carrizog60
  • 978
« Reply #3 on: February 10, 2007, 03:42:27 am »
i have done it.
not mixed on diesel but on SVO.
also added a little of 2 stroke lube
Portugal
Reply #4February 10, 2007, 04:32:59 am
« Reply #4 on: February 10, 2007, 04:32:59 am »
It's not such a good idea anymore due to the lower amount of lubrication in the diesel now. Before the ULSD and even before the LSD it was ok to mix around 10%, I'd be worried about my pump mixing it now. Use a good anti-gelling additive instead
Reply #5February 10, 2007, 07:29:57 am
mdonau
  • 53
« Reply #5 on: February 10, 2007, 07:29:57 am »
hi,
i have mixed up to 30% unleaded fuel with wvo, svo, biodiesel and normal diesel, mileage and power decreased a little.
greets, michael
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #6February 10, 2007, 07:45:24 am
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #6 on: February 10, 2007, 07:45:24 am »
I've mixed in a little white gas (coleman fuel), maybe 5-10%, to help ungel a tank.  The tank was gelled because I had too high a biodiesel ratio, so lubricity wasn't a concern.  Seemed to work fine
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #7February 10, 2007, 11:29:54 am
BlackTieTD
  • 1512
« Reply #7 on: February 10, 2007, 11:29:54 am »
Quote from: rabbid79
I remember in the Rabbit owner's manual it talked about mixing something like 10% gasoline with diesel to help keep from geling.  .
burn_your_money is right. this is no longer an acceptable practice as the lubrication in modern diesel is not the same as it was back then. if you are concerned throw some anti-gelling agent in the trunk just in case.
Reply #8February 13, 2007, 06:25:02 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #8 on: February 13, 2007, 06:25:02 am »
My '86 manual says " Only if neither No. 1 Diesel Fuel, nor winterized Diesel Fuel No. 2, nor Kerosene are available, use up to 30% leaded or unleaded gasoline.  DO NOT USE PREMIUM GASOLINE."
Of course as previously mentioned this was with older fuel, not low sulfur.
For the kerosene, it recommended up to 50% at temperatures below -10 deg. C, or 25% from -7 to -10 deg. C.
Calvin
91 VW Golf 1.6NA 5spd
Reply #9February 13, 2007, 09:39:04 am
dieselsnowmobile
  • 103
« Reply #9 on: February 13, 2007, 09:39:04 am »
On the farm, the fuel man just adds Kerosene to the off road diesel to winterize it.  I imagine that this is what is done to all diesel.  Yes, the lubrication is not there for the pump, but getting jelled is sometimes much worse than less lubrication.  Its a trade off.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #10February 14, 2007, 06:22:39 pm
knowtwodrugs
  • 46
« Reply #10 on: February 14, 2007, 06:22:39 pm »
Once it starts getting pretty cold I always put about a gallon of regular in the tank and then fill up with diesel.  That way it mixes pretty well.  My dad told me to do it.  Said it helps the engine start in the cold because gas is easier to ignite than diesel.  I don't know one way or the other, but it hasn't hurt anything.
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
 "Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
Reply #11February 14, 2007, 06:28:29 pm
« Reply #11 on: February 14, 2007, 06:28:29 pm »
throw in some 2 stroke engine oil or ATF if you are doing that, you pump will thank you.
Reply #12February 15, 2007, 12:04:58 am
« Reply #12 on: February 15, 2007, 12:04:58 am »
why mix gas with diesel though??? power service makes a really really good additive.. i've never been gelled and its nearly -20C tonight... plus it lubricates the pump, and boosts the cetane number for increased performance and better cold starts.  I get less smoke when I use power service...  and more power  8)
one jug has lasted me easily a year... but i also dont drive much... :roll:
