Author Topic: I got gelled  (Read 4927 times)
February 09, 2007, 10:03:19 am
sethyboy85
  • 284
I got gelled
« on: February 09, 2007, 10:03:19 am »
I got gelled, thought it was dirty filter, NO it wasn't
3hrs on the side of the road yesterday and 30min today to get it running again. Got some 911 diesel like product that the local guy sells and also put in 4 gallons of kero (used PS and some 5w-20w for lube). Installed a 4psi solid state pump before the filter and rigged to battery to purge system (been meaning to do so anyway) cranked for 15 sec and then she fired up idles ruff for a minute or two LOTS OF AIR in fuel line and then took it out on the road and made it all the way home with only 1 or 2 instances of maybe sucking air (or pump stopped pumping from bump)
80mi later im home and starting to warm up. Hope I don't have issues im going out tonight with the car, I spliced into the wire on the stop solenoid for the pump so when I turn the key the pump comes on now.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1February 09, 2007, 06:07:59 pm
sprstu
  • 99
I got gelled
« Reply #1 on: February 09, 2007, 06:07:59 pm »
I drove my caddy from new mexico all the way up to st paul minnesota, made the whole trip great, then the next moring I went out to get it started (even with block heater plugged it) and it was a no go. im just waiting for it to get above 0 for more than 12hrs then ill go back out and play for a bit.
Mk1 caddy TD, mk4 Golf Tdi
Reply #2February 10, 2007, 09:13:31 am
saurkraut
  • 904
I got gelled
« Reply #2 on: February 10, 2007, 09:13:31 am »
Power Service Diesel 911 might get you going again. Its at Fleet Farm, and maybe Walmart. Unscrew your fuel filter. Dispose of the diesel fuel thats in the filter appropriatly. Fill the filter with the PS 911. Re-install the filter. Dump the rest of the bottle in the tank, and attempt the start.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #3February 10, 2007, 09:42:08 am
I got gelled
« Reply #3 on: February 10, 2007, 09:42:08 am »
i wonder if you could rig up some kind of heating device for the filter housing... and if it would do much.  i've seen those hand warmer kits at Canadian tire... just wrap the filter with one of those  :wink:  if you use the anti gel/lube additives though you would completely avoid needing such mickey mouse setups hehe!   :lol:
Reply #4February 10, 2007, 03:22:46 pm
Chestrockwell
  • 95
I got gelled
« Reply #4 on: February 10, 2007, 03:22:46 pm »
You're like magellin, your so gellin'.
Reply #5February 10, 2007, 05:52:15 pm
I got gelled
« Reply #5 on: February 10, 2007, 05:52:15 pm »
Quote from: "Chestrockwell"
 :lol: i wish i was that gellin' :)
Reply #6February 10, 2007, 07:16:25 pm
Chestrockwell
  • 95
I got gelled
« Reply #6 on: February 10, 2007, 07:16:25 pm »
If you find Ellen and touch her mellon, you'll be gellin like a fellon
Reply #7February 11, 2007, 06:52:31 am
sethyboy85
  • 284
I got gelled
« Reply #7 on: February 11, 2007, 06:52:31 am »
quick somebody send the canuks some un poisened water they are all going crazy!!
or cabin fever is setting in again, in which case good luck.
Reply #8February 11, 2007, 12:25:21 pm
I got gelled
« Reply #8 on: February 11, 2007, 12:25:21 pm »
Quote from: "sethyboy85"
hehe cabin fever?? we're like this year round!  :twisted:
Reply #9February 11, 2007, 01:38:55 pm
sethyboy85
  • 284
I got gelled
« Reply #9 on: February 11, 2007, 01:38:55 pm »
I know, why do you think we didn't invade you guys and make you one of our states...  :wink:
Reply #10February 11, 2007, 01:54:47 pm
I got gelled
« Reply #10 on: February 11, 2007, 01:54:47 pm »
Before or after we kicked your ass? Remember when we burnt down the whitehouse :lol:
Reply #11February 11, 2007, 02:03:03 pm
I got gelled
« Reply #11 on: February 11, 2007, 02:03:03 pm »
Quote from: burn_your_money
Quote from: sethyboy85
pssh we left that happen, cause we wanted to remodel.
