Author Topic: m pump  (Read 20767 times)
February 03, 2007, 01:46:04 am
snakemaster
  • 405
m pump
« on: February 03, 2007, 01:46:04 am »
put a  M pump on my tdi and runs good bit i only have the std 90hp.185 injectors the prob is if give it hard throtle the car goes down to 3 clinders then 2 and after 30 meters with light throtle it goes back on to 4 clinders, and then it goes good with stedy throtle, any though on what is causing this    :?  i have the gov mod on the pump to , it even done it with the fly by wire pump
Reply #1February 03, 2007, 05:58:35 am
Slave2School
  • 531
m pump
« Reply #1 on: February 03, 2007, 05:58:35 am »
Are the injectors all tightened in enough/clean at the base?  Mine was pretty slow when I had a slight leak on two cylinders.  Some soapy water at idle might show if there are any leaks around the injectors or the glow plugs.
Waiting for a bigger better diesel to come along.
2002 ford focme wagon
Reply #2February 03, 2007, 07:22:29 pm
craiggroombridge
  • 38
m pump
« Reply #2 on: February 03, 2007, 07:22:29 pm »
sounds like a supply restriction check your fuel volume
Craig
My first was an 85 gas fun
my second is an 86 gas more fun
my third is a 92 n/a diesel project
Reply #3February 04, 2007, 04:32:45 am
Ziptar
  • 565
m pump
« Reply #3 on: February 04, 2007, 04:32:45 am »
Might be because your avatar is so huge...   :P
Really though... sounds like air is getting sucked into the fuel lines before the IP somewhere or you have a blockage / clog.
If you left it sit for a while does it also take some cranking to get it going again? In otherwords has fuel drained back to the tank?
I had almost the exact same problem on my 03 TDI a couple years back....
Went crazy all day Mity-Vac'ing all the lines and checking injectors only to find a seam had failed on the fuel filter after 8000 miles. It was a small hair line leak at the seam but, was enough to be  problem.
Reply #4February 04, 2007, 08:57:40 am
Tintin
  • 1279
m pump
« Reply #4 on: February 04, 2007, 08:57:40 am »
I wants to understand well, if i translated correctly, that gives me the effect of a timing too retard with a came plate not enough aggressive.
Here i see some TDI with AAZ pumps, and it is the same thing which occurs.
Reply #5February 04, 2007, 10:56:22 am
snakemaster
  • 405
m pump
« Reply #5 on: February 04, 2007, 10:56:22 am »
Well i dont think it is puling in air to the diesel system , car got std turbo with no pipe going to the wast gate so runs max boost 22psi , and the car only goes down 3 cilenders in 1and 2 gear under hard throtel and the rest of the time ok , going to put .216 nozzels  and a biger turbo in the next few months 8)
Reply #6February 06, 2007, 01:14:38 pm
snakemaster
  • 405
m pump
« Reply #6 on: February 06, 2007, 01:14:38 pm »
pic of my Mtdi worse for ware :roll: [/img] thats a perkins primi pump with a spacer plate i made up [/img]
Reply #7February 06, 2007, 09:50:58 pm
hillfolk'r
  • 1532
m pump
« Reply #7 on: February 06, 2007, 09:50:58 pm »
try a lift pump back at the tank
 i mean a pump(at the tank) to supply fuel to the IP
my car used to"lay down" in the higher gears before i used a supply pump to bring fuel to the front of the car
Throttle cables ftw
Reply #8February 06, 2007, 11:03:37 pm
snakemaster
  • 405
m pump
« Reply #8 on: February 06, 2007, 11:03:37 pm »
lift pump yes  next thing on my shoping list :)
Reply #9February 07, 2007, 06:14:57 am
m pump
« Reply #9 on: February 07, 2007, 06:14:57 am »
That's a Perkins pump?  Is it only available in Europe?  What model?  Thanks!
Reply #10February 07, 2007, 11:31:00 am
snakemaster
  • 405
m pump
« Reply #10 on: February 07, 2007, 11:31:00 am »
its a bosch pump but fitted to a perkins prina , that is fitted to a austin montego 2.0 tdi the engines are a bit soft and the cars are crap[/img] :lol:  :lol:  :lol:  8)
Reply #11February 07, 2007, 01:24:03 pm
m pump
« Reply #11 on: February 07, 2007, 01:24:03 pm »
When it is missing, is there smoke?  intake tube sucking shut?
Reply #12February 08, 2007, 07:22:18 am
snakemaster
  • 405
m pump
« Reply #12 on: February 08, 2007, 07:22:18 am »
No black smoke , but that intake and filter could be a prob i will change to a strate pipe and cone filtter  :)
Reply #13March 02, 2007, 12:34:11 pm
snakemaster
  • 405
m pump
« Reply #13 on: March 02, 2007, 12:34:11 pm »
pic of my mtdi when the revs get to 3800 it goes down on 3 and a little smoke out of the exhaust intake ok ,i think i need a in line pump to ceep the injection pump fool [/img]
[/img]
[/img]
Reply #14March 02, 2007, 01:32:46 pm
snakemaster
  • 405
m pump
« Reply #14 on: March 02, 2007, 01:32:46 pm »
the pump on the left hand side is of a ford escort 1.6 diesel and it has the 20mm shaft and i will change the parts out of the tdi in to the escort pump and it fits in with no mods to pulleys or bodys[/img]
