Author Topic: 12mm plunger (brand new)  (Read 5150 times)
January 31, 2007, 08:35:51 am
Benjamin
  • 485
« on: January 31, 2007, 08:35:51 am »
a brand new 12mm plunger, its original for a cummins 4bt 3.9l
its in a CLOSED package.
price: 150€
Shipping (it will be send from Belgium)
to the nederlands (holland) 10€
to europe and USA 25€
canada 35€
you can pay with paypal, we can also do this over ebay but the ebay-fees are for you.
Greetz, Benjamin
PM or [email protected]
Must make +250hp
Reply #1January 31, 2007, 09:31:05 am
« Reply #1 on: January 31, 2007, 09:31:05 am »
hmmmm with this, what else would i need to convert an old 1.6TD pump to mech TDI?
Reply #2January 31, 2007, 11:33:22 am
Benjamin
  • 485
« Reply #2 on: January 31, 2007, 11:33:22 am »
i thought at least a 20mm shaft, and a tdi camplate (the offset on the rear side is not the same as older camplates)
Greetz, Benjamin
Must make +250hp
Reply #3January 31, 2007, 08:29:23 pm
« Reply #3 on: January 31, 2007, 08:29:23 pm »
Quote from: Benjamin
Greetz, Benjamin
hmm i was just wondering about buying the pieces to make my own m-TDI pump... as this would be a great start :)  where can I find a 20mm shaft? will that 'fit' in a 1.6TD pump??? does the pump need to be machined to accept the larger shaft???
Reply #4February 01, 2007, 02:07:09 pm
Seafarer12
  • 28
« Reply #4 on: February 01, 2007, 02:07:09 pm »
Quote from: jtanguay
Greetz, Benjamin
Different pump. Pumps off of 4bt's have a 20mm shaft. The vw's have a 17mm. I have heard of people running 17mm shaft with a 12mm pump head with no problems. I think the only problem would be if you were really running it all out you might snap the shaft.
Reply #5February 01, 2007, 02:44:47 pm
Benjamin
  • 485
« Reply #5 on: February 01, 2007, 02:44:47 pm »
i'm not a vw expert, but i thought TDI's have 20mm shafts, i believe late TD's also. TDI's have an other profile camplate, i dont know you can become the same pressure rate with a TD camplate in a TDI.
On the rear side of the camplate you have the 2 pins, i think the 20mm pumps got a other offset than the 17mmshaft-pump camplate's.
i ever had a 'newer' camplate in my 'old' pump, it was my first plungerswap, when the pump was mounted on the engine it was ticking loud, much heat (watertemp), much smoke, and very bad running was the problem.
Anyway, who want this 12mm plunger  :D  is the price to high or is there just no intrests???
Greetz, Benjamin
Must make +250hp
