Author Topic: Very loud noise  (Read 9279 times)
Reply #15February 11, 2007, 08:05:51 am
Patrick
  • 1034
Very loud noise
« Reply #15 on: February 11, 2007, 08:05:51 am »
If I read your post right, you're running an SAE 40 oil. Switch to a multi grade 15w40 oil, your starter will love it. In theory these oils are the low number (sae 15) at low temp, high number (sae 40) at high temp.
Reply #16February 11, 2007, 12:31:44 pm
Very loud noise
« Reply #16 on: February 11, 2007, 12:31:44 pm »
can we get some confirmation from someone about how much oil the turbo engines hold???  I think i saw 4.7L before... and 4.4 for my old gasser.
thanks
Reply #17February 11, 2007, 02:23:11 pm
Very loud noise
« Reply #17 on: February 11, 2007, 02:23:11 pm »
My bentley does not specify TD or NA, it says
"with oil fitler change - 4.5L (4.7US quarts)"
"without oil filter change - 4.0 liters (4.2US quarts)"
That is for 81-83 engines. I don't think the pan changed much, did it?
Reply #18February 11, 2007, 02:53:16 pm
Very loud noise
« Reply #18 on: February 11, 2007, 02:53:16 pm »
the turbo oil pan has to hold more oil... it would only make sense!
stupid dipstick!!! I think i'm at the right amount of oil right now... but unsure... an oil sump level gauge would be crazy cool!!!  8)
Reply #19February 12, 2007, 11:04:11 am
Zulfiqar
  • 254
Very loud noise
« Reply #19 on: February 12, 2007, 11:04:11 am »
Im using SAE40 because its never too cold here, and even the chart in the factory VW engine manual specifies it for 1.6 litre engines in weather above 0 degrees celsius
the capacities are the same for the 1.6 turbo and NA motors, just the API classification is different.
just bought the manual today from a used books trader for 50Rs thats about 90 cents  :D
Diesel IS the future
