Author Topic: Head Gasket help.  (Read 4688 times)
January 25, 2007, 09:49:13 pm
Barry W
Head Gasket help.
« on: January 25, 2007, 09:49:13 pm »
I need to know which head gasket is the best to buy for a '91 1.6TD. I also need to know which one I need, a 2 hole or 3?
Thanks!
Reply #1January 25, 2007, 10:05:49 pm
  • 3255
    • My collection of HOWTOs
Head Gasket help.
« Reply #1 on: January 25, 2007, 10:05:49 pm »
Hi Barry.... the correct gasket to use is determined by measuring the deck height of your actual engine:
http://ep0niks.ctech.ca/vw/eva2/GE01/ch6.2.3.html
Reply #2January 26, 2007, 10:55:44 pm
Barry W
Head Gasket help.
« Reply #2 on: January 26, 2007, 10:55:44 pm »
So I need a dial gauge..... hmmmm.....
Reply #3January 26, 2007, 11:03:39 pm
  • 3255
Head Gasket help.
« Reply #3 on: January 26, 2007, 11:03:39 pm »
Princess Auto has very cheap dial gauges...
Or, jig up the one you use to set timing... or get one so that you can set the timing as well.
Or, cheat and use the 3-notch gasket.  Lots of "mechanics" take that shortcut... what you lose is the potential for not as much compression than you might have had... but overall it's probably a small thing !!
Reply #4January 27, 2007, 04:29:44 am
Head Gasket help.
« Reply #4 on: January 27, 2007, 04:29:44 am »
or just look at the gasket you have now and get the same one. There are single hole gaskets as well
Reply #5January 27, 2007, 02:46:11 pm
  • 3255
Head Gasket help.
« Reply #5 on: January 27, 2007, 02:46:11 pm »
Yup, assuming the guy who did the engine last took the time to measure... :wink:
Reply #6January 27, 2007, 04:15:29 pm
Barry W
Head Gasket help.
« Reply #6 on: January 27, 2007, 04:15:29 pm »
Sounds good. Thanks.
Reply #7March 23, 2007, 08:41:13 pm
Barry W
Head Gasket help.
« Reply #7 on: March 23, 2007, 08:41:13 pm »
Where am I looking on the gasket to determine if its a 1, 2 or 3 hole gasket?
Reply #8March 24, 2007, 04:58:13 am
Head Gasket help.
« Reply #8 on: March 24, 2007, 04:58:13 am »
Quote from: "Barry W"
it will actually have holes on the front of the gasket... easily visible with the gasket installed!  iirc it's near the IP on the front.
don't care how you measure it, just make sure you take your time doing it.. and do it right!  taking the 3 hole gasket trick is dirty... GIT ER DONE!
Reply #9March 24, 2007, 05:08:22 am
Head Gasket help.
« Reply #9 on: March 24, 2007, 05:08:22 am »
See the 3 notches beside the oil passage?
And here is a complete shot so you know where you are looking
Reply #10March 24, 2007, 06:46:36 pm
Barry W
Head Gasket help.
« Reply #10 on: March 24, 2007, 06:46:36 pm »
Oh great thanks!  Do I need to know this even if i'm gonna try the metal gasket from the 1.9?
Reply #11March 25, 2007, 07:50:59 am
1.9 gasket
« Reply #11 on: March 25, 2007, 07:50:59 am »
Yes, the 1.9 has different thicknesses too. Mine actually had holes that went through rather than notches though.
Reply #12March 25, 2007, 10:06:28 am
Head Gasket help.
« Reply #12 on: March 25, 2007, 10:06:28 am »
that's true, some have holes and some have notches
Reply #13March 25, 2007, 10:02:18 pm
Barry W
Head Gasket help.
« Reply #13 on: March 25, 2007, 10:02:18 pm »
Great info. Thanks guys!
