Author Topic: Ruff starting '04 tdi  (Read 4159 times)
January 18, 2007, 09:47:39 am
Powered by Spearco
  • 1203
« on: January 18, 2007, 09:47:39 am »
I dont know if this is anything to be worried about, but when I start my
car in the morning it seems to run ruff and smoke a little bit then clear up.
It's a '04 tdi/PD. It's got 43k miles and has had regular matinance.
It's also been cold, upper 20s to mid 30s F.  I use the recomended synthetic oil for VW. Should I be concerend or is that normal for the start up when cold out.
   Thanks, Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #1January 18, 2007, 09:58:53 am
« Reply #1 on: January 18, 2007, 09:58:53 am »
i'd say it could be a bad glow plug... or glow plug wiring...
Reply #2January 18, 2007, 04:38:09 pm
Doug
« Reply #2 on: January 18, 2007, 04:38:09 pm »
Get a clip-on ammeter to do some checks to see that your glow system is drawing sufficient current. I don't know what the specs are on TDI glows but the book or dealer will tell you. One of my old diesels had an auxillary ammeter in series with the glow bus. It was an easy way to keep an eye on its condition. (you probably don't want to do that to a spiffy '04)
