General Information
Troubleshooting
Is this compression tester "worth it?"
Topic: Is this compression tester "worth it?" (Read 8536 times)
January 16, 2007, 10:19:22 am
jackbombay
January 16, 2007, 10:19:22 am »
Ebay auction
Its certainly inexpensive compared to what I thought they would cost, I was expecting something more like
this
. I won't be using it a whole lot, there are a few old IDIs around here that need some "starting issue" troubleshooting. Anyone have the cheap ebay one? It looks like it has adapters to use the GP holes, is that the most common way to test the compression?
January 16, 2007, 11:05:09 am
saurkraut
January 16, 2007, 11:05:09 am »
Its a compression test kit from Harbor frieght. Buy it directly from harbor freight:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93644
The picture on their web page is from an older kit. If you buy from Ebay, you get the same harbor freight P/N. the directions in the Ebay kit have the same P/N and clearly say Harbor frieght.
I payed more than $24 when these first showed up on Ebay over a year ago.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
January 16, 2007, 11:08:11 am
jackbombay
January 16, 2007, 11:08:11 am »
With $16 of shipping for the ebay auction and only $7 from HF it works out better from HF, Thanks!
Do you test the compression using an adapter in the GP holes? I also see adapters that look like they replace the injectors.
January 16, 2007, 11:57:04 am
January 16, 2007, 11:57:04 am »
i bought the kit too... i bet you could probably test compression through the GP holes... but why bother??? you'd need to crack the injector line anyways... it would also be VERY awckward to get in there too...
January 16, 2007, 01:32:39 pm
jackbombay
January 16, 2007, 01:32:39 pm »
Ahhh, I was thinking of the TDI configuration.
Sounds like it'll do the trick, I'm getting it.
January 17, 2007, 02:06:24 pm
January 17, 2007, 02:06:24 pm »
I just bought one as well, just make sure your IP is completly dry when doing the comp test. flame really screws up the schrader valve in the end of the adaptors. Experiance speaking here.
January 17, 2007, 11:58:15 pm
LeeG
January 17, 2007, 11:58:15 pm »
simpler to pull the wire off the fuel relay than to drain the IP I think
'97 Passat TDI
January 18, 2007, 05:48:46 am
Doug
January 18, 2007, 05:48:46 am »
Princess Auto carries a diesel compression guage with adapters to fit the injector holes. One of them in the kit fits the VW. It works well and because you remove the injector nozzle body there is no threat of fire or liquid contaminating the test equipment. It is definitely not as cheap as the Harbour Freight item. I can't imagine attemting to screw adapters into the glow plug holes on a 1.6. That one is just a pain in the ass to service even to replace the glow plugs!
January 18, 2007, 06:42:52 am
January 18, 2007, 06:42:52 am »
hooking into the GP hole is easy on some models though... such as the toyota 2.4D engine (the gp's are right at the top
March 30, 2007, 10:17:51 am
rallydiesel
March 30, 2007, 10:17:51 am »
So the HF version has adapters for the injector holes? Will these work on a TD engine?
1991 Jetta TD - sold
2001 Golf TDI - Son's
March 30, 2007, 10:41:33 am
Doug
March 30, 2007, 10:41:33 am »
Seeing as you live in Saskatchewan you will have a Princess Auto somewhere nearby. I have no idea about the Harbour Freight item. The Princess one does have adapters to fit other diesel engines but I cannot confirm the TDI VW. You might have to fabricate one using an old injector body from a TDI engine. The guage and kit are well made but you are going to have to lay out somewhere around the hundred dollar mark when it is on sale. While Princess does sell some cheap stuff of questionable quality, whenever I have had a problem, I take it back with the receipt. Money is refunded even after several years. So keep those receipts!
Reply #11
March 30, 2007, 02:48:08 pm
Reply #11 on:
March 30, 2007, 02:48:08 pm »
Quote from: rallydiesel
Yes
Reply #12
March 30, 2007, 02:48:56 pm
dieselsnowmobile
Reply #12 on:
March 30, 2007, 02:48:56 pm »
Just remember to have new heat shields ready when you take your injectors out.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #13
March 30, 2007, 04:13:43 pm
rallydiesel
Reply #13 on:
March 30, 2007, 04:13:43 pm »
Where do you get heatshields from?
Reply #14
March 31, 2007, 05:34:40 am
Doug
Reply #14 on:
March 31, 2007, 05:34:40 am »
Go to Carquest and ask the parts guy to open up "Worldpac", or to NAPA opening up "Atrom" on their search programs. They carry this stuff.
General Information
Troubleshooting
