Author Topic: 90 Jetta, engine locked up  (Read 10101 times)
Reply #15March 15, 2007, 07:57:05 am
« Reply #15 on: March 15, 2007, 07:57:05 am »
So I discovered why it was not turning over.
Started by removing the head but there is a bracket on the front behind the IP that needed to be removed so the IP came off.
As soon as the IP was off I could see the problem.
It seems there is a crank inspection hole, I.E. non factory installed hole in the front of the block.
It apparently also has some non factory installed quick release rods as one of them is sticking out the inspection hole
On the good side, the head appears to have been rebuilt recently. Clean clean.
So the search for a hydro 1.6 block ensues.
Reply #16March 15, 2007, 10:42:16 am
Doug
« Reply #16 on: March 15, 2007, 10:42:16 am »
Why do you think the hole with the rod was there? Seems very odd.
Reply #17March 15, 2007, 10:50:41 am
« Reply #17 on: March 15, 2007, 10:50:41 am »
Perhaps the same crank inspection hole with the quick release rods as this guy ?
http://www.youtube.com/watch?v=4g7_bHlQhd8
Reply #18March 15, 2007, 11:06:09 am
« Reply #18 on: March 15, 2007, 11:06:09 am »
Quote from: Doug
my first guess would be poor reassembly.
the inside of this engine looks brand new, like it was just refreshed.
The #1 rod let go.
I'm preaty much going to have to replace the entire bottom end.
Crank
Balance shaft
Balance shaft pully
rods/ pistons
Reply #19March 15, 2007, 11:22:17 am
« Reply #19 on: March 15, 2007, 11:22:17 am »
Quote from: Vincent Waldon
Ya, I've seen that vid.
Only problem is the VW isnt supose to hve that hole eh?
 :x
Reply #20March 15, 2007, 11:54:24 am
« Reply #20 on: March 15, 2007, 11:54:24 am »
In my air-cooled days I drove a Beetle with an impromptu crank inspection hole for a couple hundred km... you could actually watch the piston go up and down and everything.  Finally just for laughs I drove it to my favorite VW shop and asked if they had any Crazy Glue... when he asked why I took him outside and started her up... "it started making a funny noise a week ago".
Reply #21March 15, 2007, 01:30:16 pm
Doug
« Reply #21 on: March 15, 2007, 01:30:16 pm »
Did the rod let go at the big end? I have seen a patch welded on the crankcase below the water jacket on such an event, mind you not on a VW but an ancient Brit machine and it worked too.
Reply #22March 15, 2007, 08:06:55 pm
« Reply #22 on: March 15, 2007, 08:06:55 pm »
Well I've not got it tore down far enough yet to see how bad it really is so I'll have to report on that later.
You are correct however, repairing blocks really isnt that hard.
Lock-N-Stitch lock comes to mind. Good stuff right there.
http://www.locknstitch.com/
