Author Topic: PLEASE GIVE ME A BREAK! (overheating)  (Read 7829 times)
January 10, 2007, 07:05:02 am
SMOKEYDUB
  • 630
« on: January 10, 2007, 07:05:02 am »
I just cant do it anymore.....the cooling system wont bleed out all it does is steam like a mofo. Overheats,pressurizes the coolant so much it pops the cap and pisses its coolant out. I can never get the coolant to flow well and i have all new coolant stuff accept rad it it flows well so....I havnt checked my timing but when i have the cap off when im trying to bleed it out i the cooland will sometimes jump out of the coolant bottle.The only other thing i can think of is the headgasket AGAIN (4) I have arp headstuds torqued to there spec. Please help wtf am i missing????
Thanks
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1January 10, 2007, 09:44:23 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #1 on: January 10, 2007, 09:44:23 am »
I don't envy you.
If it does all this when cold, then it sounds like head doom of some sort. If when hot, a circulation hassle of some sort.
A few things to look at,
1) The head was straight? Smooth? No deep gouges across the fire rings?
2) The block was straight?
3) No big cracks in the head or block? Apart for 0.5mm between valves.
4) Bolts torqued in the right order?
5) Thermostat? If missing, the bypass hose will bypass the radiator!
6) Internal collapse of bottom radiator hose? Might only happen when revving.
7) Impeller of water pump slipping on the shaft? Had this on another car, it certainly had me scratching my head, I don't know if it's one that veedubs suffer from.
A quick test, put the coolant in (or most of it), start engine & run for 30 seconds, turn off, squeeze radiator hoses, if rock hard, bad news, gasses are escaping into the coolant.
Good Luck
Reply #2January 10, 2007, 11:55:27 am
« Reply #2 on: January 10, 2007, 11:55:27 am »
Could be the old rag in a hose factor?
Reply #3January 10, 2007, 02:56:59 pm
andy2
« Reply #3 on: January 10, 2007, 02:56:59 pm »
This engine (1.6) still has the 1.6 head on it or the 1.9 head?
Could be a porus or cracked head I just went through this my cyl head It was so screwed that I got another head due to poor welding repair and or high stress and high boost/EGT's doesn't help either.Have you tried using another head?I actually had boost pressure entering my cooling system not combustion pressure/gases.
Also does your rad fan work?Have you tried manually powering up the fan to see if it changes anything.It does however sound like you are getting some serious pressure entering your cooling system from either the head or headgasket.
Are you torquing those studs down to 120 ft lbs with motor oil?
Just some thoughts,Hopefully we'll get this fugured out!
Reply #4January 10, 2007, 04:11:51 pm
wyldman
  • 403
« Reply #4 on: January 10, 2007, 04:11:51 pm »
Did it puke the coolant out first ? Or did you change it and now can't bleed it ?
My Golf is a PITA to bleed.You fill it,and if you leave the cap off,it starts puking it back out.If you leave the cap on,it slowly heats up and then will overheat if you let it.
I've found that the rad itself is the biggest place for trapped air.Mine will get all the hoses hot,but the drivers side of the rad will stay cold.
Now what I do,is remove the upper hose,and hold it way up in the air.Fill it right up until it won't take anymore.Now reach down and "pump" the lower hose to help push the air through.you will hear it gurgle,and the level will drop.Keep doing this until it's full.now reconnect the upper,and fill the tank.That should get most of it.I then put the cap on,and run the engine about 2500 RPM until the stat opens.The reservoir should drop again,and you can top it off.
(416)565-7282
Reply #5January 10, 2007, 04:24:55 pm
wolfsburgnut
  • 126
« Reply #5 on: January 10, 2007, 04:24:55 pm »
What I do to bleed the coolant system, and this seems to work really well, is I cup my hands to the top of the resevoir to make a loose seal and blow into the resevoir.  Pretty soon you will here the coolant burping out the air.  I managed to 5 litres of coolant into the system this way before startup.
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #6January 10, 2007, 04:41:07 pm
SMOKEYDUB
  • 630
« Reply #6 on: January 10, 2007, 04:41:07 pm »
its been doing it for a while i think its head or headgasket.anyways today i put my winter beater on the road (95 passat AAZ).So i will have time to put another engine in it (stock td) and stick my "GOOD" one in my rabbit which is currently equipped with the 1.6 head and am later goin to the 1.9 one.
(courtesy of GILES)
Reply #7January 10, 2007, 04:52:43 pm
« Reply #7 on: January 10, 2007, 04:52:43 pm »
I've found that the easiest and fastest way to bleed to coolant system on mk1s and early mk2s (before the round tank upgrade) is to squeeze and hold the upper rad hose. Then cover the overflow line from the rad to the res with your finger, and let go of the upper rad hose. Repeat this until a steady stream of coolant comes out of the small hose. I also always drill a 1/8 hole in my thermostat if it didn't already come with one from the store.
This would be easy enough to do with the later style tanks as well
As for your problem SMOKEYDUB I think your head is cracked, seeing as you have gone through 4 HGs already
Reply #8January 10, 2007, 05:34:38 pm
« Reply #8 on: January 10, 2007, 05:34:38 pm »
i kinda messed up changing my thermostat too... i didn't fill the rad first and the driver side was cold and the engine was getting pretty hot.  took the cap of the reservoir off, and as soon as the thermostat opened, bubbles came out and the coolant level rose up quite a bit.  turned the car off and it sucked some coolant back through.  topped it off and done.  there may still be some air in the system though...
you don't have the stock cooler do you???
i really do wish there was a mod to install a merc diesel head on our engines...  never ever have to worry about heads warping...
Reply #9January 10, 2007, 06:29:45 pm
« Reply #9 on: January 10, 2007, 06:29:45 pm »
fill the motor through the upper radiator hose if you haven't that seems to help.
Reply #10January 10, 2007, 07:42:28 pm
LeeG
  • 401
« Reply #10 on: January 10, 2007, 07:42:28 pm »
I always try to keep track of how much coolant I have put back in vs how much came out or the capacity so I have some idea about trapped air.
Squeezing the lower rad hose repeatedly before and after starting seems to help shift the air around.  With the '91 TD it seems to take 5 minutes or so of squeezing and topping up tank until 80-90% of coolant is in place, any air remaining seems to bubble out quickly once t-stat opens.
I second the hole in t-stat.  I usually try to get ones with a hole that has the little rattle thing in the hole to keep it from plugging up.  Most seem to have it these days.  Failing that I drill a 1/8" hole at top edge of tstat.
'97 Passat TDI
Reply #11January 10, 2007, 11:41:49 pm
  • 2932
overheating
« Reply #11 on: January 10, 2007, 11:41:49 pm »
Is the restrictor in the overflow hose clogged up?
 Do you have coolant/air flowing through this hose and into the resevoir.
 My resevoir overflows when the thermostat opens too.
Reply #12January 11, 2007, 12:51:16 pm
SMOKEYDUB
  • 630
« Reply #12 on: January 11, 2007, 12:51:16 pm »
i do fill up the engine throught the upper rad hose and non of the tubes have any blockage.and yes i still have the factory heat exchanger. One thing came to mind the other day... I have my cylinder head really ported out i wonder since the walls are probably so thin it transfers alot more heat to the cooling system.hmmmmm.
(courtesy of GILES)
Reply #13January 11, 2007, 08:31:12 pm
« Reply #13 on: January 11, 2007, 08:31:12 pm »
Quote from: SMOKEYDUB
well i guess it may/may not be the factory heat exchanger... because mine only gave me problems when it was hot.  it was pressurizing hoses, etc.
i think it would really be worth a shot at taking a look at your cooler... will save a lot of time/aggravation if thats the culprit!
Reply #14January 14, 2007, 08:00:00 pm
SMOKEYDUB
  • 630
« Reply #14 on: January 14, 2007, 08:00:00 pm »
thanks for the input guys im currently drivin my diesel passat for the winter so i have tim to pull it out and fix it and dump it in my rabbit. Im going to build a nice little stock 1.6 for the jetta and use a k03 on it so i can drive it without thrashing it to get light to light power.
(courtesy of GILES)
