Author Topic: Change bore 1600 to 1700. Got some questions  (Read 10903 times)
Reply #15January 11, 2007, 06:10:16 am
Audi80
« Reply #15 on: January 11, 2007, 06:10:16 am »
I like IDI´s better too 8)
I just started collecting parts for it, start building after few months. Maybe I´ll start my own topic then.  :)
At first I have to get Scirocco running with 1,6TD from my earlier Audi. I´m installing 02A transmission at the moment.
Reply #16January 11, 2007, 06:52:49 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #16 on: January 11, 2007, 06:52:49 am »
I'm also installing a 02A (G60 almoste same internals as the 020 4T) in my Jetta 1. With a 1.6N/A diesel so I can go to the road admitance office to get her changed from 1300 carb. to diesel.
After that I'm going to build something nice for her. ;)
Reply #17January 21, 2007, 05:57:48 pm
  • 2932
1.7 pistons
« Reply #17 on: January 21, 2007, 05:57:48 pm »
OK here's a picture of them:
 A couple pics that is:
Reply #18January 23, 2007, 12:32:42 am
2mAn
« Reply #18 on: January 23, 2007, 12:32:42 am »
is it possible to just bore the 1.6 NA block to fit the 1.7D pistons?
Reply #19January 23, 2007, 02:25:15 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #19 on: January 23, 2007, 02:25:15 am »
@fatmobile: thanks for the images.
@2manVR6: Yes that can be done. With a 1900TD head fitted on the engineblock.
Reply #20January 23, 2007, 02:36:37 am
  • 2932
1.7
« Reply #20 on: January 23, 2007, 02:36:37 am »
Yeah, I put the picture of the old pistons next to the new 1.7s to show that the pin sits at the same height and is nearly the same diameter.
 I'm putting these in a solid lifter 1.6TD block so i won't be able to use the 1.9 hydro head... but that would be a better setup.
Reply #21January 24, 2007, 06:15:28 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #21 on: January 24, 2007, 06:15:28 am »
Why a solid lifter block?
Can't you drill the oil squirters in a hydro block and put the 1900TD head on it?
Reply #22January 24, 2007, 03:43:57 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
« Reply #22 on: January 24, 2007, 03:43:57 pm »
hi all,
this a great topic for me, as i have realised that i have a rare engine, and in excelnt condition, so i have decided some weeks ago to turbo it, at the moment it does not have piston cut outs or the oil squirters,
i plan to get them machined into the block and bolt up a 1.6 head, 1.9 gasket, intercooler and see what sort of power it nets me. i figured that if i'm spending money on a rebuild why not start with a good base as the 1.7 is the best i have then that the way i'm heading.
what sort of powr do you recon it could make? 130 bhp with xtra fuel and boast.
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #23January 31, 2007, 12:54:49 am
  • 2932
« Reply #23 on: January 31, 2007, 12:54:49 am »
 I don't have a hydrolic block and can't find one. I haven't done any boring and am hoping that one will show up soon and that I can afford it.
Reply #24January 31, 2007, 07:34:31 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #24 on: January 31, 2007, 07:34:31 am »
Aha now it's clear to me. (my answer was allready there....  :oops:  )
Reply #25January 31, 2007, 09:21:17 am
« Reply #25 on: January 31, 2007, 09:21:17 am »
hmmm the 1.7 piston is on the right in those pics??? it doesn't have the cutout for the piston oil squirter... if you install piston oil squirters with those pistons, won't be long before the oil squirters get trashed into the oil pan... or cause damage :(
is it possible to get 1.7 pistons with the squirter hole??? must be $$$ to get it done at a machine shop...
Reply #26February 01, 2007, 06:44:11 pm
  • 2932
1.7 pistons
« Reply #26 on: February 01, 2007, 06:44:11 pm »
 no, that's a nasty old set of NA pistons.
 The 1.7s are the new ones,  on the left.... with the oil squirter slots
Reply #27February 20, 2007, 07:35:31 pm
subsonic
  • 1836
Re: 1.7 pistons
« Reply #27 on: February 20, 2007, 07:35:31 pm »
Quote from: fatmobile
I pulled this off a post titled 1600 to 1700.  The pistons on the left have what appears to be cut outs for oil squirters.
I would think this set-up would make for a nice high reving engine.  Is it lack of piston availability that keeps this from happening?
