Author Topic: boost comes at redline...doesent peak  (Read 7943 times)
Reply #15January 07, 2007, 10:05:19 am
  • 5104
« Reply #15 on: January 07, 2007, 10:05:19 am »
i believe your wastegate is stuck closed like mine,  you're going to have to find someone to get it loose, try removing the metal line from the wastegate and then putting the aircompressor on it, this freed mine, but make sure you drive around alot afterwards, and shoot lube down in there to get it nice and loose.  and hopefully it will stay free, otherwise you'll have to pull the wastegate off and clean it.  the way yours is now,  the only way to control boost is with more or less fuel.  you'll always have as much as there is boost, like on my jetta, more fuel just made more and more boost.  your only option to get it to work is to free the wastegate somehow
Reply #16January 07, 2007, 10:12:14 am
carrizog60
  • 978
« Reply #16 on: January 07, 2007, 10:12:14 am »
so is there a way to check if it is real stuck?
i thought the problem was if it was open...if its closed it would be ok...
so if i can get it loose it will change the boost reactions right?
i want to have full boost at 3000 or 3500 not at red-line...
Portugal
Reply #17January 07, 2007, 10:43:37 am
  • 5104
« Reply #17 on: January 07, 2007, 10:43:37 am »
if it was open you would have low boost, and if you have 1.6 bar, thats a good bit so, i'm asuming it's not open, you can make sure it's not stuck open, by taking a 10mm deep well socket and loosening the lock nut on the wastegate, then you need a 3mm allen wrench, and tighten the adjustment the entire way, then loosen it back to either where it was, or until the screw gets very loose, then tighten it again until it touches then lock it back.  if that frees your wastegate which it could, then you'll stay at around 10psi.
Reply #18January 07, 2007, 01:30:10 pm
carrizog60
  • 978
« Reply #18 on: January 07, 2007, 01:30:10 pm »
well so i think that could not be the problem because i was at 0.6 bar stock and to increase boost i put the 3mm allen bolt all the way in and the boost came. :idea:
Portugal
Reply #19January 07, 2007, 01:38:37 pm
  • 5104
« Reply #19 on: January 07, 2007, 01:38:37 pm »
well thats the problem then, if you want it to peak you have to loosen it some, you either have it shut the entire way or you have it set at a pressure your not fuelign enough for to reach
Reply #20January 07, 2007, 02:34:46 pm
carrizog60
  • 978
« Reply #20 on: January 07, 2007, 02:34:46 pm »
but how can i have 1.6bar at loer rpm?
even with this setup i have some smoke on boost...
Portugal
Reply #21January 07, 2007, 03:13:20 pm
« Reply #21 on: January 07, 2007, 03:13:20 pm »
you will need to mess with your fuel screw for that kind of boost.  a larger exhaust will definitely help too.
i would also recommend that you take off the intake plumbing going to the turbo and shine a light and see if you can verify the state of the turbine blades.  there should be little or no clearance for the blades, and they should be straight and not curvy.  bent blades will give poor boost qualities.
Reply #22January 08, 2007, 03:06:46 am
carrizog60
  • 978
« Reply #22 on: January 08, 2007, 03:06:46 am »
i have a good intercooler but no EGT yet.
so there is no point on adding the MBC right?
i just wanted to increase boost at "lower"(read 3000)rpm because i still see light some on boost.
thought that on boost all the smoke would be gone that way
Portugal
Reply #23January 08, 2007, 01:24:18 pm
carrizog60
  • 978
« Reply #23 on: January 08, 2007, 01:24:18 pm »
thanks...
i will try to see if my wallet let me change the downpipe for one with no restriction.
also,i have my pump timing at stock.would it help to advance it a bit?
to what values?
Portugal
Reply #24January 09, 2007, 02:10:30 pm
carrizog60
  • 978
« Reply #24 on: January 09, 2007, 02:10:30 pm »
anyone?
Portugal
Reply #25January 09, 2007, 02:56:54 pm
  • 5104
« Reply #25 on: January 09, 2007, 02:56:54 pm »
1mm to 1.05 is what people say is the best, i haven't messed with timing yet
Reply #26January 09, 2007, 03:24:20 pm
« Reply #26 on: January 09, 2007, 03:24:20 pm »
i can start my car without the cold start pulled now... before i had to even with 5C weather.. the timing is around 1.06mm :)
Reply #27January 09, 2007, 03:56:06 pm
carrizog60
  • 978
« Reply #27 on: January 09, 2007, 03:56:06 pm »
what would be the benefits and downside in performance/reliability on setting the pump at 1 or 1.05 or more?
sorry about all the Q... :oops:
Portugal
