Author Topic: Extra Ground Strap  (Read 3833 times)
January 02, 2007, 05:35:55 pm
TW
  • 39
Extra Ground Strap
« on: January 02, 2007, 05:35:55 pm »
Thanks for the tip on an extra  ground strap attached to the starter.  I put one one yesterday.  I had no trouble starting the car when the engine  was cold and the glow plugs had to cycle, but it took a fair amount of cranking to get it started warm.  Now with the extra ground, it starts easily when warm because the starter turns twice as fast.
Reply #1January 02, 2007, 08:07:46 pm
Extra Ground Strap
« Reply #1 on: January 02, 2007, 08:07:46 pm »
One of my favorite, cheapest upgrades for any engine :)
Reply #2January 03, 2007, 05:01:52 pm
Barry W
Extra Ground Strap
« Reply #2 on: January 03, 2007, 05:01:52 pm »
Hmm good tip.   :)
Reply #3January 05, 2007, 11:11:18 pm
hillfolk'r
  • 1532
Extra Ground Strap
« Reply #3 on: January 05, 2007, 11:11:18 pm »
yea i painted an engine trans combo up all purty once.....
upon reassembly it wouldnt start unless i added the aux ground  strap
i even had to add one from the  alt  to the v/c
the paint was hindering the grounding,so i always add extra grounds
thats important also if you  have electric guages
if the engine isnt grounded good,the guages will read erratic
sometimes you can "see " a bad ground
watch to see if the speedo needle jumps upon cranking
if so its trying to  "find" a ground thru the very fragile speedo head
too much of that,and its toast
Throttle cables ftw
