My coolant temp seems to be a little high?
Pages:
Topic: My coolant temp seems to be a little high? (Read 7897 times)
Reply #15
January 01, 2007, 06:53:39 pm
Reply #15 on:
January 01, 2007, 06:53:39 pm »
i've tested the connector that goes to the thermoswitch (different than the thermostat, which is YES definitely a big PITA since the power steering pump is in direct interference.. i may switch my car to mechanical steering in the future... less aggravation and one less thing to break
ok back on topic... the leads from the thermoswitch do work as i have jumped them, and the fan works on both speeds. but i do not think that the thermoswitch is opening the circuit at the correct temps. probably due to guy i bought it from putting in a cheap napa one that blows... i will always buy thermostats and thermoswitches from my owasco dealer from now on. i love my thermostat and will never EVER try a different one. i nearly get heat coming out of my vents after 3 minutes of being on. my last thermostat would barely give any heat after 8 minutes of driving... you get what you pay for i guess...
one thing you can check for too is corrosion on the contacts... it's fairly common as there is a lot of current running through that connection. your best bet is to get penetrating lube and either spray the connector & thermoswitch and just insert it repeatedly, or get a wire brush and try that. i'm not 100% sure if mine have contact, but i did clean them really well.
btw.. what resistor are you guys talking about? there is one built into the fan for high/lo and there is also an ultra low speed for A/C with the resister attached to the fan itself. if that resistor blows the fan should still kick on lo/hi, but a/c won't work (but if your resistor is blown, there is probably no gas left in your system from the overheat...)
Reply #16
January 01, 2007, 07:16:52 pm
mk2vr6
Reply #16 on:
January 01, 2007, 07:16:52 pm »
I've got the resistor on the back of the fan motor for the A/C, and the A/C works so it must work. And the fan DOES come on for me but only once the temp gauge has reached 3/4. And, it seems, that it comes on and off for a few mins and then once it hits a certain temp it appears to no longer come on at all.
89 Golf GL VR6T
92 Golf GTI 16v
92 Jetta 1.6D
92 Jetta 1.6TD
Reply #17
January 01, 2007, 07:30:10 pm
dover
Newbie
Reply #17 on:
January 01, 2007, 07:30:10 pm »
My particular 91 eco has 2 resistors integral with the rear of the fan motor (it's the one motor / 2 fans unit).
One was fried along with the big 5 or 6 wire connector and the other one suffered fatigue from me f*king with it.
BD BD
Reply #18
January 01, 2007, 08:54:45 pm
wyldman
Authorized Vendor
Reply #18 on:
January 01, 2007, 08:54:45 pm »
It's perfectly normal to see these cars run just above halfway,or even a little closer to the 3/4 mark.It will go higher when pushed hard,running hills,or with the A/C on in hot weather.
To change the start on the cars with PS,you need to get it out of the way.Without A/C,it's a 3 min job.The hardest part is getting the thermostat up in there,with the o ring in place,and getting it to stay in place while you get the housing back on.
(416)565-7282
Reply #19
January 04, 2007, 08:47:52 pm
Reply #19 on:
January 04, 2007, 08:47:52 pm »
My rabbit has weird problems, like very little heat inside the car with 180F or 195F t stats. With the 195 the temp needle is on the bottom red line, with the 180 the needle is in the middle. I put the temp sender in boiling water(207F at my altitude) and the needle was just under the 3/4 mark. Does that mean I've been running at 220F all the time? I've driven about 1000mi with the needle in the red and it still works fine. About the heater, both heater hoses are so hot I can't hold either one of 'em but the air coming out is not very warm, it's also a new heater core. I've had the heater box out a couple times checking for air leaks and there are none. I put a thermometer in the stream of coolant the shoots back into the reservior and with the 180 t stat the temp was 165F, with the 195 t stat the temp was 187F. Thats over 20* more with a t stat thats only 15* hotter. :?
Any help will be very nice as I have racked my brain for a month or two trying to solve the problem :roll: By the way, this is a sweet site w/ tons of good info
P.S I live Alaska so a good heater is a must! It's -30F right now and getting colder. Driving at -25F is normal :cry: poor car :roll:
Reply #20
January 04, 2007, 09:08:31 pm
wyldman
Authorized Vendor
Reply #20 on:
January 04, 2007, 09:08:31 pm »
Either the heater core is plugged,or your temperature blend door is out of adjustment or broken.
(416)565-7282
Reply #21
January 05, 2007, 08:32:34 am
veeman
Reply #21 on:
January 05, 2007, 08:32:34 am »
Yeah... I'd definitely check that heater control valve there in the engine compartment. I've had a few fail on me, but it's a pretty cheap part ($15) and pretty easy to change (when it's not -30 out, that is).
Seems like your engine is getting plenty warm...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #22
March 17, 2007, 06:24:25 pm
Reply #22 on:
March 17, 2007, 06:24:25 pm »
hmmm here to dig up this thread again... my car still heats up quite a bit on a hard run.
funny thing, is that at idle the car's temp is PERFECT. same with another jetta I have. except the other jetta has another problem. drive it down the road, and the temp gauge falls dramatically... weird... the faster I drive with my current jetta though, the hotter it gets. (especially confusing when there's a -10C headwind.....)
so my guess is that the rad cap is faulty and not bleeding out some of the air pressure in the system, creating an air lock in the rad.
oh and I KNOW for a fact that the rad fan is not coming on either... the temp climbs steady too. rad fan does come on at idle though... I've considered water pump, but I haven't noticed any sudden drops in RPM to indicate belt slip.
Pages:
