Author Topic: drive axles splines on newer axles  (Read 3427 times)
December 30, 2006, 01:00:18 pm
Justin
  • 455
« on: December 30, 2006, 01:00:18 pm »
So I had some axles modified for an Audi TT transmission and now I am using a beetle trans, well the CV joints are different and I was wondering if anyone new if the inner axle splines were the same on the TT axles and the Beetle axles. I assume that they are but I dont want to buy some and then have them not work
thanks for the help.
Later
Justin
www.archeryprostaffmi.com
Reply #1January 02, 2007, 06:21:45 am
Justin
  • 455
« Reply #1 on: January 02, 2007, 06:21:45 am »
bump,
does anyone have a newer beetle or golf TDI and happen to have the axles out or able to remove one and give me the sizes?
thanks
Justin
Reply #2January 02, 2007, 09:53:04 am
Darkness_is_spreading
  • 288
« Reply #2 on: January 02, 2007, 09:53:04 am »
You really need to check,  the sline count on them,  just order them from a auto shop, and come in with your Beetle CV shaft and compare the Audi TT shaft bring your caliper. Thats the only way I would suggest trying to compare them,  but they will prob be different based on the High end Audi TT, having almost nothing in relation to the Beetle..... IE ( Quattro)
92 Jetta 1.6 T (Sleepin)
