Author Topic: Intercooler sizing?  (Read 3797 times)
December 26, 2006, 07:49:39 am
flash319
  • 163
Intercooler sizing?
« on: December 26, 2006, 07:49:39 am »
How does one determine the right size of intercooler?  I would assume that one that is too big (volume) will cause a lag as the pressure builds.  Also one that is to small will not be as effective at cooling temperatures.
Trial and error or what?
Reply #1December 26, 2006, 11:02:25 am
Intercooler sizing?
« Reply #1 on: December 26, 2006, 11:02:25 am »
libbybapa is right (as always)
bigger is better.  even if you have a 2-5 psi drop, just imagine how much the charged air temps will drop.  a small intercooler will become hotter faster, and be less able to discharge that extra heat as fast, so you get 'heat soak' which is not good at all.
i'm going to be building a water intercooler setup sometime in the summer, but for now i'm trying to fit in at least a small intercooler.  my water intercooler heat exchanger will be huge :)  but the actual intercooler will be nice and small, and fit even with a/c still installed :)
Reply #2December 29, 2006, 05:26:29 am
TomB
  • 88
Intercooler sizing?
« Reply #2 on: December 29, 2006, 05:26:29 am »
Apparently ones from Merc Sprinter vans are good (if you can find a cheap one).  Cheers for that nugget of info gents, once I've got it running right, fitting a larger intercooler is on my list of things to do...
Cheers,
Tom
1.6 Golf GTD - Chip Fat Powered!
Reply #3December 29, 2006, 08:33:12 am
andy2
Intercooler sizing?
« Reply #3 on: December 29, 2006, 08:33:12 am »
http://putfile.com/pic.php?pic=5/12317064757.jpg&s=f5
My intercooler in this pic is probably as big as any 1.6/1.9 would ever need!
Reply #4December 29, 2006, 11:21:28 am
flash319
  • 163
Intercooler sizing?
« Reply #4 on: December 29, 2006, 11:21:28 am »
Where did you get that one from?  That is what I need for my truck.
Reply #5December 29, 2006, 02:08:17 pm
andy2
Intercooler sizing?
« Reply #5 on: December 29, 2006, 02:08:17 pm »
I got it from some fly by night out of his garage type place on Ebay.That particular Intercooler is compact as its only 2.5" thick with 2.5"in/out.Most I/C's I've seen are 2.5"in/out but are 3" thick which was no good for me.If you can put a 3"thick IC on you truck then thats your best bet as they are more common.
Reply #6December 29, 2006, 04:44:19 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
Intercooler sizing?
« Reply #6 on: December 29, 2006, 04:44:19 pm »
Sprinter IC has plastic ends, and they are 90° sharp bended...Can it hold 1.5 bar of pressure?
Just if someone would like to know, IC is the same that is in VW LT...
Excuse me on my bad English
Reply #7December 29, 2006, 09:38:11 pm
Typrus
  • 93
Intercooler sizing?
« Reply #7 on: December 29, 2006, 09:38:11 pm »
That looks like a Powerstroke intercooler....
The brick in our 1Z Passat TDI is 7 3/8" wide, 8 3/16" tall, 3 5/16" thick, with 1 5/8" ID in/outlet. Works well with the Passat, but would work far better if it actually had some nice airflow.
I think one of the main reasons for the pressure drop is the thermo-contraction of the air, resulting in less volume filling the same space=less pressure.
So if a 5PSI drop occured, you're likely seeing huge temp drops.
I'd go with the largest one you can fit where ever you can fit it. It'll lag when the turbo first starts to turn over and build a baseline system pressure. In other words, startup. Past that, the lag should be near unnoticeable just from a bigger intercooler.
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
Reply #8December 30, 2006, 08:29:05 am
andy2
Intercooler sizing?
« Reply #8 on: December 30, 2006, 08:29:05 am »
http://www.msnusers.com/gtdforum/shoebox.msnw?action=ShowPhoto&PhotoID=20
This is the intercooler form a 6.0L ford with the powerstroke. Almost enough room :lol: .
Reply #9December 30, 2006, 10:15:05 am
Typrus
  • 93
Intercooler sizing?
« Reply #9 on: December 30, 2006, 10:15:05 am »
I'm fairly sure the stock 7.3L intercooler is smaller than the stock 6.0L. Odd how a larger needs a smaller. Both of those are Powerstroke Diesels.
