Author Topic: 1985 Jetta 1.6lTD clutch pedal to the floor?  (Read 5690 times)
December 23, 2006, 11:22:08 am
jonz
  • 28
« on: December 23, 2006, 11:22:08 am »
Okay, so i am a not so well versed on working on cars...
I was driving around the block this morning, and i heard an almost ripping sound when i pushed the clutch pedal. I had half clutch for one more shift, and now i have nothing. I was able to limp home in second gear.
I looked behind the pedals, and it appears that the clutch pedal isnt attached to anything. So i can only assume that the clutch cable broke?
I do have some basic mechanics tools, and a knack for picking up things. Is this something i can do myself? Any insight into making the job easier?
Thanks in advance!
JonZ in Colorado
I did some searching around, but i couldn't find anything on this topic.
1985 VW Jetta TD
Loveland, Co.
Reply #1December 23, 2006, 02:03:46 pm
BlackTieTD
  • 1512
« Reply #1 on: December 23, 2006, 02:03:46 pm »
hey there,
yep, sounds likely its the clutch cable. very simple job to install a new one, a bit trickier to adjust it. if you look at the top of the clutch pedal you will see where it hooks on. the other end goes through the clutch arm on the transmission and is held with a clip. take a look at what is there as you remove the old and you should be able to install the new with the reverse process. have fun, happy holidays. -bttd
Reply #2December 23, 2006, 03:40:40 pm
« Reply #2 on: December 23, 2006, 03:40:40 pm »
Hopefully a snapped cable is all that happened. It is the most likely problem though. Further investigation will defintly show you.
Hopefully none of your metal pieces that hold the cable to the arm fell off and got lost. All vws 1974-1992 for sure have the same pieces, gas and diesel alike.
Reply #3December 29, 2006, 05:22:33 am
TomB
  • 88
« Reply #3 on: December 29, 2006, 05:22:33 am »
A friend of mine and I did one on a petrol Golf a couple of weeks back, and it took all of half an hour.  It's good to have assistance for the adjustment, but apart from that, it's not too tricky.
Good luck!
Tom
1.6 Golf GTD - Chip Fat Powered!
Reply #4December 30, 2006, 10:13:29 am
jonz
  • 28
« Reply #4 on: December 30, 2006, 10:13:29 am »
Is there any way someone can do me a humongous favor?
I am still waiting on the part... (Damn blizzardx2)
I am pretty sure i can reverse engineer putting this bad boy in, but was wondering if someone with a Bentley(mine is on order) could scan the pages for this procedure and email them to me? Please!
Send me a private message if this is somethign that you would be willing to do for me!
Much thanks in advance,
JonZ in Colorado
PS.
This site is fantastic and loaded with a ton of wonderful knowledgeable people. After i get this thing fixed i will post my whole story of this wonderful little vehicle along with pics!
1985 VW Jetta TD
Loveland, Co.
Reply #5December 30, 2006, 01:24:08 pm
dover
  • 18
bentley
« Reply #5 on: December 30, 2006, 01:24:08 pm »
except fot the fact that this message showed up:
CTech.ca is currently undergoing maintenance.
We plan to be back online on 2006-12-29 11:00 AM
this site gains you access to bentley:
http://ep0niks.ctech.ca/
BD BD
Reply #6January 02, 2007, 05:24:47 pm
jonz
  • 28
« Reply #6 on: January 02, 2007, 05:24:47 pm »
That site is still down, so i went ahead and gave it a try...
She is purring like a kitten again!! Only took me about 20minutes total by myself... Maybe i am better at this than i thought =)
Thanks for your input guys it is much appreciated!
JonZ in Colorado
1985 VW Jetta TD
Loveland, Co.
Reply #7January 02, 2007, 08:02:27 pm
« Reply #7 on: January 02, 2007, 08:02:27 pm »
good to hear you are up and running again
