Author Topic: Which turbo is best for me?  (Read 3065 times)
December 18, 2006, 08:34:47 pm
« on: December 18, 2006, 08:34:47 pm »
I have a KKK and garrett off a 1.6 and a k14 and a k03 off a 1.9. I run my car in ECO mode (LDA disconencted) Apparently (according to Hagar) it will lower the soot in my oil, and extend the life of my engine and get better mileage. I'm wondering what turbo is going to provide me with the most boost most of the time. I do alot of highway driving and I usually shift around 2700 rpm, cruising rpm is kept between 2k and 3k
Eventually I am going to get a VNT, but thats a few years away I think
What would you recommend? or is it a trial and error thing?
Reply #1December 19, 2006, 06:55:01 am
« Reply #1 on: December 19, 2006, 06:55:01 am »
K03 for sure.  you will have next to no smoke as it should spool right off the line.  should help to burn the soot :)
personally i'd rather just keep the power, and install an fs2500 bypass filter :)
Reply #2December 20, 2006, 04:23:19 am
« Reply #2 on: December 20, 2006, 04:23:19 am »
I have no smoke as it is. Actually I noticed a bit last night for the first time since I changed my air filter. It's only been on there for a month, or 7k kms. I'll have to have a look at it.
K03 eh... what would be my best second choice?
Reply #3December 21, 2006, 08:29:17 pm
« Reply #3 on: December 21, 2006, 08:29:17 pm »
With the mk3 turbos they each have their own exhaust manifold right?
Reply #4December 21, 2006, 09:10:41 pm
zagarus
  • 619
« Reply #4 on: December 21, 2006, 09:10:41 pm »
is there no love for garrett turbos?
Reply #5December 22, 2006, 06:42:49 am
QuickTD
  • 1156
« Reply #5 on: December 22, 2006, 06:42:49 am »
Quote from: "zagarus"
If you can find a garret T2 from an early passat AAZ they are a good small turbo, similar to a K03 in performance. The T2 also fits the trapeziodal flange 1.6TD manifold.
Reply #6December 22, 2006, 04:41:19 pm
« Reply #6 on: December 22, 2006, 04:41:19 pm »
Quote from: "libbybapa"
The Garrett and K24 both have considerable lag and without boost enrichment might even have trouble reaching stock boost pressures of 9-10psi...
Andrew
Maybe that's why my car really kicks it up a notch between 3000-4500 in first
