Author Topic: AAZ water pump  (Read 6159 times)
December 18, 2006, 04:01:35 pm
AAZ water pump
« on: December 18, 2006, 04:01:35 pm »
Are there any higher flow water pumps that will fit an AAZ, or pumps off
a different engine that would flow more?
Reply #1December 18, 2006, 05:52:22 pm
QuickTD
  • 1156
AAZ water pump
« Reply #1 on: December 18, 2006, 05:52:22 pm »
Why? Pumping water costs power and economy. Ideally you want to pump as little as possible while still keeping the temps under control.
Reply #2December 18, 2006, 08:53:33 pm
water pump
« Reply #2 on: December 18, 2006, 08:53:33 pm »
In case I need it to keep temps under control. Hopefully I won't though.
Reply #3December 18, 2006, 09:08:12 pm
AAZ water pump
« Reply #3 on: December 18, 2006, 09:08:12 pm »
If your thermo stat is doing it's job you shouldn't need to worry. A larger rad would work as well for lowering the temperature if the current rad isn't
Reply #4December 20, 2006, 01:13:10 pm
Otis2
  • 191
AAZ water pump
« Reply #4 on: December 20, 2006, 01:13:10 pm »
Agreed.  Water temperatures are not as big a concern as oil temperatures on an AAZ, in my experience.
I don't know how heavy your Land Rover is, but the guys who have AAZ engines in VW Vanagons all report pretty high oil temps.
If high oil temps become a concern, plan for a sandwich-plate adapter and air-cooled oil cooler.
Don't waste your time with trying those bigger oil/water heat exchangers, promoted by Diesel Geek & others.  I went this route and it had little effect on cooling the oil, but a big effect on my wallet.  (It did warm the engine up faster, but that's not why I bought it.)
A bigger turbo than your stock AAZ turbo will drop the oil temps, but mostly because it won't spool as well as your tiny K03.  If it's not spooling, then it's not heating the oil.  For an off-road crawler, I would think the early spool of the stock AAZ turbo would be a big advantage.
Reply #5December 20, 2006, 02:19:39 pm
AAZ water pump
« Reply #5 on: December 20, 2006, 02:19:39 pm »
i would say go for a bigger rad, and air cooled oil cooler.  would be nice to keep the stock exchanger on though, just to have faster warmups :)
Reply #6December 20, 2006, 04:55:39 pm
water pump
« Reply #6 on: December 20, 2006, 04:55:39 pm »
Quote from: Otis2
Water temps got to at least 250(limit of my gauge). I have one air/oil
cooler, but have since been given a 2nd one, an intercooler, and a
slightly larger new al radiator for cheap. I am fitting a VNT 15 turbo,
putting in totat seal rings, and had to buy a new head due to the over
heating. Supprisingly I didn't see any signs of leaking a head gasket,
but I had deep cracks, one prechamber that falls out on it's own, and
the rest are somewhat loose.  My truck weighs 3500, so quite a bit more
than the rest of you, which is probably why it gets hotter. I actually
had a k14 on it, which still spooled well. Anyway, in trying to cover
all the bases, I know that more water flow cools better, so that's why
I was asking. I did have a new thermostat in, so that wasn't the problem.
Stock cooler is also on as I had to use it to fit the remote filter kit.
